Rear Brake bleeding question |
Frankvw |
May 21 2020, 10:09 AM
working on my first 914 ! Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi all, I replaced the calipers and pads and flex hoses in the rear. (1973 1,7)
Old brake fluid from reservoir removed with siringe and filled with new fluid. I did set the clearance on the inner and outer on both sides. Then I did bleed the brakes and checked the clearance again (was still OK) Now the proportioning valve part....do I need someone to push the pedal to the floor, keep pedal at floor and then I bleed again while pedal is down? Or does it work another way ? Or is it not needed after what I already did ? Thanks for your reply ! |
davep |
May 21 2020, 10:49 AM
914 Historian Group: Benefactors Posts: 5,220 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Do you have a proper solid pedal feel? If you circle the block and stop at each corner, does it feel normal? The proportioning valve should not really need any special consideration.
Lo-Fi Version | Time is now: 27th December 2024 - 11:47 PM |
