HOW TO: Install a main wiring harness, plus, identify the wires ... |
i love porsche |
Jun 24 2004, 09:03 AM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
i need your help..i just got a wiring harness in the mail...and im trying to identify all the parts...i did a little..but i couldnt get far..im not very good at reading the wiring diagrams
so i took pictures of each part and im hoping you guys could possibly tell me where they go i really appreciate all the help i can get Attached thumbnail(s) |
SirAndy |
Jun 24 2004, 02:41 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
a few tips about installation:
the whole harness must be installed from inside the cabin! everything that goes to the back of the car, rear trunk, engine comp, center tunnel has to be fiddled in from the FRONT of the center tunnel backwards! meaning, the taillight wires first, then string the whole back end through. NOTE: in the front part of the center tunnel, the harness routing is *different* for early/late cars! don't miss that first hoop or you won't be able to fit the mount for the floor board! it's a lot easier to fiddle the big connectors through tight holes FIRST, even if they're not the first thing in the harness, if you feed the smaller wires first, the bigger connectors won't fit anymore. this will take some practice (IMG:style_emoticons/default/biggrin.gif) yes, all the engine and rear trunk stuff fits through the rear firewall hole, even the big rubber boot! trust me, you can do it! btw. it *REALLY* helps having a second person sitting in the engine comp while you feed the stuff through! once the rear is in place, feed the front part through the front firewall (left from the steering wheel). same here, feed bigger connectors first! (IMG:style_emoticons/default/smash.gif) Andy |
Archie |
May 28 2020, 02:49 PM
Member Group: Members Posts: 197 Joined: 23-September 09 From: Western Canada Member No.: 10,844 Region Association: Pacific Northwest |
a few tips about installation: the whole harness must be installed from inside the cabin! everything that goes to the back of the car, rear trunk, engine comp, center tunnel has to be fiddled in from the FRONT of the center tunnel backwards! meaning, the taillight wires first, then string the whole back end through. NOTE: in the front part of the center tunnel, the harness routing is *different* for early/late cars! don't miss that first hoop or you won't be able to fit the mount for the floor board! it's a lot easier to fiddle the big connectors through tight holes FIRST, even if they're not the first thing in the harness, if you feed the smaller wires first, the bigger connectors won't fit anymore. this will take some practice (IMG:style_emoticons/default/biggrin.gif) yes, all the engine and rear trunk stuff fits through the rear firewall hole, even the big rubber boot! trust me, you can do it! btw. it *REALLY* helps having a second person sitting in the engine comp while you feed the stuff through! once the rear is in place, feed the front part through the front firewall (left from the steering wheel). same here, feed bigger connectors first! (IMG:style_emoticons/default/smash.gif) Andy Thanks a tremendous bunch for this, Your Excellency! I'm at the removing stage and you've just stopped a lot of head scratching! (Mine!) |
Lo-Fi Version | Time is now: 27th December 2024 - 10:35 AM |
