> TPS variations - has anyone else noticed this ?, trouble shooting and comparing 2 with same part numbers but different stop tabs etc
DRPHIL914
post Jun 8 2020, 09:52 AM
Dr. Phil
i will post a picture here of 2 OE TPS with part number that cross references to the 75-76 2.0 D-jet cars.
i recently pulled mine due to it bucking badly @ 2800-3400 rpm on part load or mild acceleration.
i also have one from Gatornapper to test for him and he is sorting out his D-jet parts and prepping to eventually going back from carbs to FI.
What i found was that the stop peg is located on a different place. his
essentially stops the tps from going all the way to the bottom at idle but not at the top on acceleration.
mine on the right. stops the pivot of the shaft from going all the way on the top and keeps it from being able to go off track on max, his would not.
they have the same part number. neither had been tampered with.
also i bought mine as an NOS part 7-8 years ago and now may need to be replaced.
his on the left has much more wear, actually live testing it causes same bucking but at a different lower rpm, due to wear pattern.
any thoughts? i will be putting a new board on mine as soon as it arrives
Right now i am running with it unplugged and no skip buck or hesitation now. i had been thinking it may have been an issue with my rebuilt MPS or developers valve set up or a wire shorting somewhere else, but it’s the TPS.
Nojoah
post Jun 8 2020, 10:50 AM
Hmm interesting. The TPS I pulled off of my stock 74 2.0 -
DRPHIL914
post Jun 8 2020, 12:18 PM
Dr. Phil
QUOTE(Nojoah @ Jun 8 2020, 12:50 PM) *
Interesting, that is really worn bad!! same part # on the board/13 , as the one in my pic on the left , what is the part number on the back side?
Nojoah
post Jun 8 2020, 04:24 PM
QUOTE(DRPHIL914 @ Jun 8 2020, 02:18 PM) *
Definitely worn - pulled it off for replacement as I was experiencing similar bucking. Sorry I don't believe I have a picture of the part number on the back this was a few weeks ago. (IMG:style_emoticons/default/confused24.gif)
DRPHIL914   TPS variations - has anyone else noticed this ?   Jun 8 2020, 09:52 AM
SirAndy   The part number printed on the boards is different...   Jun 8 2020, 10:22 AM
DRPHIL914   The part number printed on the boards is differen...   Jun 8 2020, 10:26 AM
DRPHIL914   The part number printed on the boards is differen...   Jun 8 2020, 10:40 AM
Nojoah   Hmm interesting. The TPS I pulled off of my stock ...   Jun 8 2020, 10:50 AM
DRPHIL914   Hmm interesting. The TPS I pulled off of my stock...   Jun 8 2020, 12:18 PM
Nojoah   Interesting, that is really worn bad!! sa...   Jun 8 2020, 04:24 PM
bdstone914   Try a pencil eraser to clean it up. If the metal i...   Jun 8 2020, 04:30 PM
nordfisch   You won't have to replace the board. Just cle...   Jun 11 2020, 12:10 PM
DRPHIL914   You won't have to replace the board. Just cl...   Jun 11 2020, 12:45 PM
nordfisch   231 is the number on mine, you are saying that t...   Jun 11 2020, 01:23 PM
DRPHIL914   231 is the number on mine, you are saying that ...   Jun 11 2020, 01:30 PM
nordfisch   [quote name='nordfisch' post='2824128' date='Jun ...   Jun 11 2020, 02:25 PM
DRPHIL914   ok update: took advice here and i cleaned the sur...   Jun 13 2020, 02:30 PM
DRPHIL914   thought i’d post a picture after cleaning up the...   Jun 15 2020, 06:19 AM
nordfisch   Hi, the cold engine needs extra fuel AND extra air...   Jun 15 2020, 12:28 PM
DRPHIL914   Hi, the cold engine needs extra fuel AND extra ai...   Jun 16 2020, 07:23 AM
Gatornapper   Phil - "disconnecting the decel allows the r...   Jun 16 2020, 09:57 AM
JeffBowlsby   Using the decel valve is said to reduces stress on...   Jun 16 2020, 10:08 AM
DRPHIL914   Using the decel valve is said to reduces stress o...   Jun 16 2020, 10:23 AM
JeffBowlsby   "...so other than just only allowing a slig...   Jun 16 2020, 10:43 AM
- Lo-Fi Version Time is now: 19th April 2025 - 06:36 PM
