Cold Compression test 2.0, 4 cylinders at 150 result |
ndfrigi |
Jun 9 2020, 02:56 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
two weeks ago I drained oil, cleaned the strainer screen and taco plate cover, add new oil and filter and did the valve adjustments.
Before I did the valve adjustments, the compression rates (cold) was 150, 148, 165 and 175. So after valve adjustments still cold engine, all are around 150. Is it a good compression as cold engine and what should I expect when the engine is warm? thank you! |
ndfrigi |
Jun 9 2020, 06:37 PM
Thank you Zach and Tom!
Lo-Fi Version | Time is now: 25th June 2024 - 11:09 PM |
