dt4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England ![]() ![]() |
RoadGlue |
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California ![]() ![]() |
Do you mean on the second fuel line? There's a lot going on in this photo, so it's hard to know what you're talking about.
The car has both a feed and return line for the fuel system, but if you car was swapped to carbs at some point, then the return line isn't used and may explain why it's disconnected. The wire and connector hanging is the fuel level sender connection, which plugs in on the top of the tank. |
dt4 |
Do you mean on the second fuel line? There's a lot going on in this photo, so it's hard to know what you're talking about. The car has both a feed and return line for the fuel system, but if you car was swapped to carbs at some point, then the return line isn't used and may explain why it's disconnected. The wire and connector hanging is the fuel level sender connection, which plugs in on the top of the tank. sorry, I realise now that I wasnt very clear you have answered all the questions between you The car is on carbs which explains why there isnt a pipe on the return |
DickSteinkamp |
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None ![]() |
dt4 |
Lo-Fi Version | Time is now: 26th June 2024 - 11:52 AM |
