Pdr1787 |
Sneaky Pete ![]() ![]() Group: Members Posts: 55 Joined: 8-September 09 From: Lakewood, California Member No.: 10,779 Region Association: Southern California ![]() |
Hi everyone,
Long story short, someone cut my main harness to rig up my car to work. The relay board was tossed as well. Now I have rewired and fixed the main wiring harness. bought a relay board and ignition harness (I have a carb set-up now). I do not see any positive lead to the fuel pump. I'm not sure where the positive lead come from originally and the ignition harness i bought doesn't have it. Any tips on how do I go about this?? Thanks in advance (IMG:style_emoticons/default/poke.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Fuel pressure light in the gauge cluster? (IMG:style_emoticons/default/dry.gif) What color is that light? (IMG:style_emoticons/default/blink.gif) You are going to need to post pictures. (IMG:style_emoticons/default/wacko.gif) do you possess a Haynes manual?
Pdr1787 |
Fuel pressure light in the gauge cluster? (IMG:style_emoticons/default/dry.gif) What color is that light? (IMG:style_emoticons/default/blink.gif) You are going to need to post pictures. (IMG:style_emoticons/default/wacko.gif) do you possess a Haynes manual? It actually was the light on the right hand side of the gauge. Not the oil pressure light. Also I found the fuse for the fuel pump was out. Inserted a new fuse and wallah. I can hear the fuel pump working. I just need to add brake fluid and bleed the brakes. Buy some gas and I should be able to start her right up. It’s been six years. I rebuilt the front and rear end. have a brand new motor from fat performance and transmission from rancho performance transmission. I’m super excited and I want thank all you guys for your help, tips and tricks. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 27th June 2024 - 07:05 PM |
