> Time to un-DAPO the "new" car, Bad things happened to a nice car
BillC
post Jun 27 2020, 11:30 AM
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole:
Once I took the rockers off, I discovered this:
Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is.
In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location).
BillC
post Jun 27 2020, 06:23 PM
So, continuing down the list of discoveries:
There was a mess of wires hanging down under the dash. Most of it is for the aftermarket radio, but there was one wire connected to a toggle switch under the dash.
One end of the switch was connected to ground. I dug into the dash and discovered the other end was spliced into the tach wire from the coil. So, it appears to be a shade-tree anti-theft device, grounding the coil to kill the ignition. However, that might also explain why the tach doesn't work.
Here are a couple more pics of how the fuel pump wire ran through the passenger compartment:
Speaking of holes in the firewall, I found this lovely on the driver's side:
It wasn't connected to anything, but may have been a remote trunk release. Although, other than the hole in the firewall, I didn't find any other holes related to it.
The fuel pump wire hole and the pull handle hole are the largest holes drilled in the firewall, but there are at least 10 other holes of various sizes drill in it.
Under the car, I discovered that the original vinyl fuel hoses are still in the center tunnel. However, they did splice in new hoses between the firewall and the engine compartment (stock vinyl hoses in the engine compartment, too).
And, of course, none of the heating parts are connected. They did install new stainless heat exchangers and a muffler. However, they are for a 1.7, not a 2.0. But, they did not replace the muffler hanger with the correct one. Instead, they drilled new holes to move it upward and then created home-made adapter brackets to connect it to the muffler.
It turns out that the stainless heat exchangers are in really nice shape. Any chance anyone might want to trade these for some nice 2.0 exchangers? I'll eventually post pics in a "trade" post on the for-sale board, after I get a chance to wash them off.
Tomorrow, the plan is to drain the fuel, drop the engine and pull the tank (if there's time). Who knows what fun is lurking under the tank?
barefoot
post Jun 28 2020, 01:35 PM
The 1.7/1.8 SS heat exchangers have the same tube sizes as the 2.0. so no need to replace them. If you're anal about the muffler bracket you can easily find a 1.7/1.8 version.
have fun with the other fixes.
BillC
post Jun 28 2020, 05:48 PM
QUOTE(barefoot @ Jun 28 2020, 03:35 PM) *
Yeah, I know the tubes are the same size, and that the 1.7 exchangers will work just fine. However, I am kinda anal about making the car "right". And, I'd rather reinstall the exchangers just once if I can, rather than put these in for now and change them later on.
BillC   Time to un-DAPO the "new" car   Jun 27 2020, 11:30 AM
Montreal914   Front mounted oil cooler or AC? :confused: Look f...   Jun 27 2020, 11:32 AM
SirAndy   Front mounted oil cooler or AC? :confused: Look ...   Jun 27 2020, 11:43 AM
BillC   Front mounted oil cooler or AC? :confused: Look ...   Jun 27 2020, 12:06 PM
BillC   But, so far, the "best" has to be the ho...   Jun 27 2020, 12:16 PM
SirAndy   I cut it off with a pair of snips. I'll take ...   Jun 27 2020, 03:01 PM
BillC   [quote name='BillC' post='2828616' date='Jun 27 2...   Jun 27 2020, 05:22 PM
BillC   And, in the archaeology department, here's a c...   Jun 27 2020, 12:23 PM
BillC   It turns out that the car may have it's origin...   Jun 27 2020, 12:27 PM
preach   It turns out that the car may have it's origi...   Jun 27 2020, 05:49 PM
Chris914n6   The foam is factory correct for an early car. It...   Jun 27 2020, 12:30 PM
BillC   The foam is factory correct for an early car. It...   Jun 27 2020, 12:44 PM
mepstein   The foam is factory correct for an early car. It...   Jun 27 2020, 04:11 PM
ClayPerrine   [quote name='BillC' post='2828626' date='Jun 27 2...   Jun 27 2020, 04:46 PM
ClayPerrine   Trying to "Un-DAPO" the car. I am sti...   Jun 27 2020, 03:17 PM
Cairo94507   I hope they disclosed all of those issues prior to...   Jun 27 2020, 05:42 PM
BillC   I hope they disclosed all of those issues prior t...   Jun 27 2020, 06:06 PM
BillC   So, continuing down the list of discoveries: Ther...   Jun 27 2020, 06:23 PM
barefoot   The 1.7/1.8 SS heat exchangers have the same tub...   Jun 28 2020, 01:35 PM
BillC   The 1.7/1.8 SS heat exchangers have the same tu...   Jun 28 2020, 05:48 PM
BillC   So, we got the engine and fuel tank out yesterday....   Jun 29 2020, 10:56 AM
SirAndy   For what it's worth, i really like the color...   Jun 29 2020, 12:25 PM
BillC   For what it's worth, i really like the color...   Jul 1 2020, 04:12 PM
Craigers17   This situation seems particularly frustrating....e...   Jul 1 2020, 04:43 PM
Superhawk996   This situation seems particularly frustrating.......   Jul 1 2020, 05:02 PM
BillC   This situation seems particularly frustrating.......   Jul 1 2020, 05:22 PM
2mAn   :WTF: :chair:   Jul 1 2020, 04:56 PM
Wyvern   When I started reading this I did not know what a ...   Jul 1 2020, 05:03 PM
BillC   Made more progress today. Removed the rear window...   Jul 2 2020, 05:19 PM
Montreal914   Not sure what your front sway bar setup is but I d...   Jul 2 2020, 05:50 PM
BillC   Not sure what your front sway bar setup is but I ...   Jul 2 2020, 05:53 PM
BillC   It doesn't seem like I accomplished much today...   Jul 3 2020, 04:44 PM
BillC   Well, I didn't make as much progress as hoped ...   Jul 6 2020, 04:26 PM
Cairo94507   Very nice. You are making great progress and tack...   Jul 6 2020, 05:54 PM
Front yard mechanic   If you ever sell the car think what the next owner...   Jul 6 2020, 08:07 PM
BillC   If you ever sell the car think what the next owne...   Jul 7 2020, 06:36 AM
Superhawk996   If you ever sell the car think what the next own...   Jul 8 2020, 06:40 AM
get off my lawn   If you ever sell the car think what the next owne...   Jul 7 2020, 03:20 PM
IronHillRestorations   Sad to see the misfortune of some cars. I hope my...   Jul 7 2020, 03:16 PM
BillC   The order with the rubber isolator finally came, s...   Jul 9 2020, 07:08 PM
BillC   Today I worked on reinstalling the fresh air box. ...   Jul 11 2020, 04:19 PM
BillC   Time to tackle the hacked-in hole by the foot peda...   Jul 12 2020, 02:39 PM
914werke   Good idea on the Wire support.   Jul 12 2020, 03:00 PM
Superhawk996   Like the wire support execution. My donor tunne...   Jul 12 2020, 03:58 PM
BillC   Like the wire support execution. Thanks, but it...   Jul 12 2020, 07:17 PM
ClayPerrine   Like the wire support execution. Thanks, but i...   Jul 12 2020, 09:50 PM
BillC   And now, let's go after this lovely bunch of h...   Jul 13 2020, 07:17 PM
BillC   The lovely bunch of holes, continued: Here's ...   Jul 13 2020, 07:29 PM
Superhawk996   :trophy: Like the screw as a handle. Still had ...   Jul 14 2020, 07:50 AM
BillC   Like the screw as a handle. Still had to have bee...   Jul 14 2020, 12:35 PM
kroelofsen   :Qarl: Nice work...!   Jul 14 2020, 11:53 AM
bkrantz   Be fair! I am sure most 914s were free of rus...   Jul 14 2020, 08:29 PM
BillC   Be fair! I am sure most 914s were free of ru...   Jul 15 2020, 04:34 PM
BillC   Time to do more work on the fuel system. First, n...   Jul 17 2020, 04:52 PM
barefoot   Next, is to mount the fuel pump and fuel filter. ...   Jul 18 2020, 02:13 PM
Superhawk996   :cheer:   Jul 18 2020, 08:43 AM
Cupomeat   Love this thread! Thankfully I've had my 9...   Jul 18 2020, 09:05 AM
BillC   Love this thread! Thanks! Sometimes I w...   Jul 18 2020, 06:27 PM
bkrantz   Love this thread! Thanks! Sometimes I ...   Jul 18 2020, 08:33 PM
BillC   Did you consider mounting the pump on the undersi...   Jul 19 2020, 05:51 AM
BillC   Anyway, finally got the pump, filter and hoses ins...   Jul 18 2020, 06:27 PM
BillC   So, the parts I've been waiting for finally ar...   Jul 23 2020, 02:11 PM
Superhawk996   Here are the pliers reassembled and holding a r...   Jul 23 2020, 02:33 PM
BillC   Last night, I glued the perlon back on the front b...   Jul 24 2020, 03:27 PM
BillC   This is what the battery tray looked like: This i...   Jul 26 2020, 10:38 AM
Frankvw   good trick with adjusting these pliers ! Ques...   Jul 27 2020, 01:05 AM
BillC   good trick with adjusting these pliers ! Que...   Jul 27 2020, 02:20 PM
Frankvw   "If you want, I'll take more pictures of ...   Jul 27 2020, 02:25 PM
BillC   Well, it's been too long, but I finally had a ...   Aug 9 2020, 06:32 PM
porschetub   you have great metal fab skills,well done but expe...   Aug 9 2020, 09:14 PM
BillC   Didn't plan on it taking so long for this next...   Aug 23 2020, 06:02 PM
BillC   Well, it's been waaaay too long since I made a...   Oct 12 2020, 04:01 PM
Tdskip   Nice going, and thanks for the updates!   Oct 13 2020, 09:02 AM
BillC   It's finally time to take on the last "DA...   Oct 22 2020, 02:22 PM
BillC   I was able to spend some time with the car this we...   Nov 2 2020, 03:32 PM
Cairo94507   Very very nice work. :trophy:   Nov 2 2020, 04:42 PM
StarBear   Very very nice work. :trophy: :agree:   Nov 28 2020, 10:45 AM
BillC   I took advantage of the federal holiday to spend a...   Nov 11 2020, 04:17 PM
Morph914   Your thread makes me realize how fortunate I was t...   Nov 11 2020, 08:10 PM
bkrantz   Your thread makes me realize how fortunate I was ...   Nov 28 2020, 08:58 PM
BillC   I had some time yesterday to work on the car, so I...   Nov 28 2020, 10:07 AM
Superhawk996   Then, after I was finished with the mirror holes...   Nov 29 2020, 10:25 AM
BillC   Now it's time to tackle a common 914 problem (...   Nov 29 2020, 04:21 PM
Cairo94507   Chasing the rust is a very very slippery slope. I...   Nov 29 2020, 04:43 PM
BillC   So, the new sander belts came in and I got back to...   Dec 5 2020, 05:07 PM
BillC   And . . . done! It even works! I need ...   Dec 6 2020, 12:13 PM
Superhawk996   And . . . done! No getting off that easy....   Dec 21 2020, 09:01 AM
BillC   And I agree: grad school sons are sometimes helpf...   Dec 21 2020, 09:32 AM
barefoot   And . . . done! No getting off that easy...   Dec 22 2020, 12:31 PM
BillC   And, now for the moment you've all have been w...   Dec 20 2020, 05:00 PM
AZBanks   Great work. Looks really good.   Dec 20 2020, 07:01 PM
bkrantz   Looks great. And I agree: grad school sons are so...   Dec 20 2020, 09:16 PM
PanelBilly   Reading this makes me want to build another car. F...   Dec 21 2020, 12:01 AM
Cairo94507   Bill, @BillC , great job. So nice to see that do...   Dec 21 2020, 10:12 AM
bbrock   Just getting caught up on your thread. Fantastic ...   Dec 22 2020, 02:29 PM
BillC   It may look like not much has happened since the l...   Jan 10 2021, 11:43 AM
pete000   Just remember that is wasn't all that long ago...   Jan 10 2021, 03:25 PM
BillC   Time to take on the last rusty area I've found...   Jan 17 2021, 02:16 PM
BillC   I was able to spend more time today on the car, st...   Jan 18 2021, 07:27 PM
jaredmcginness   Nice work! I used 16g for that section on my c...   Jan 19 2021, 05:38 AM
- Lo-Fi Version Time is now: 4th December 2024 - 08:06 PM
