BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 550 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: ![]() Once I took the rockers off, I discovered this: ![]() Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). ![]() |
BillC |
So, we got the engine and fuel tank out yesterday. And, the DAPOs didn't disappoint.
On the engine, where the Decel Valve should be, I found this: ![]() Yup, that's a fuel pressure regulator on a home-made mounting bracket. It does look similar to a decel valve, but they're just not quite the same thing. Plus, they didn't bother connecting or plugging the vacuum line that connects to the decel valve, so there's the source of the high idle. In the front, they did mount the fuel pump and filter under the tank. However, they did it by using a sheet metal screw to attach a hose clamp and then clamped the pump, with a little bit of old hose for noise dampening. ![]() Not really a great mount, but probably the least "DAPO" thing they did to the car. The previous owner did mention that the car seemed to lose power at higher speeds. I think I may have found out why: ![]() Apparently that crimp isn't enough to stop the car from running, but came very close. Also explains why it took so long to drain the fuel tank. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:11 PM |
