> Rebuilding Koni Shocks Cost, More $$ than I was expecting
RoadGlue
post Jul 1 2020, 10:32 AM
Sonoma County Gear Head
I'd always expected when the time came to have my Koni sport shocks/struts rebuilt, it could be done so at a significant savings over buying new parts, but the quote I got back from Performance Shock over at Sonoma Vly Raceway was $275/per corner, but it could be more if they needed additional parts to bring them back up to spec. They were great to chat with, and were clear that if the shocks were still available new then that's the way to go.
Is that a typical price? I was honestly just going to have them done as I've just ordered everything I need to rebuilt my suspension, steering and brake systems from the ground up. Once I have the front end disassembled I may find that they're still good, but I'm sure they're at least 15-20 years old.
Mark Henry
post Jul 1 2020, 09:15 PM
that's what I do!
Are you sure the front bushings haven't seized?
My fronts were hard as a rock, like a go carts solid (no) suspension. Took the struts off and the A-arms barely budged. I used full motion bearings and the arms fell right vertical, bolted up the struts and couldn't believe the difference.
porschetub
post Jul 2 2020, 03:03 PM
QUOTE(Mark Henry @ Jul 2 2020, 03:15 PM) *
Thanks Mark,replacement Boge struts cured the issue,arms were free.
RoadGlue   Rebuilding Koni Shocks Cost   Jul 1 2020, 10:32 AM
GregAmy   It is typical. Unless you have some spiffy revalvi...   Jul 1 2020, 10:44 AM
Retroracer   I got quoted the same price from the same vendor. ...   Jul 1 2020, 10:48 AM
GregAmy   Note that Koni builds the dampers in bulk on a pro...   Jul 1 2020, 10:56 AM
Krieger   Hey Randy! The guys at PSI can also dyno your...   Jul 1 2020, 11:14 AM
RoadGlue   Hey Randy! The guys at PSI can also dyno you...   Jul 1 2020, 11:21 AM
mepstein   The rebuild service is for someone who wants custo...   Jul 1 2020, 11:18 AM
RoadGlue   The rebuild service is for someone who wants cust...   Jul 1 2020, 11:50 AM
Matt Romanowski   Koni shocks cost more to rebuild because of how th...   Jul 1 2020, 12:20 PM
porschetub   Koni shocks cost more to rebuild because of how t...   Jul 1 2020, 07:54 PM
rhodyguy   When the service is performed, do internally adj a...   Jul 1 2020, 12:37 PM
914Sixer   The kicker to all this is the fact that the rear h...   Jul 1 2020, 01:37 PM
live free & drive   I sent some Koni red struts out to PSI to be rebui...   Jul 1 2020, 01:39 PM
Mark Henry   Are you sure the front bushings haven't seized...   Jul 1 2020, 09:15 PM
porschetub   Are you sure the front bushings haven't seize...   Jul 2 2020, 03:03 PM
9146BRUCE   Hi I sent 2 sets of the rear coilovers for truchoi...   Jul 1 2020, 10:09 PM
horizontally-opposed   Normal pricing. Had them check two Koni Red rear...   Jul 1 2020, 11:34 PM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th November 2024 - 04:30 PM
