Nogoodwithusernames |
Member ![]() ![]() Group: Members Posts: 281 Joined: 31-May 16 From: Sutter, CA Member No.: 20,051 Region Association: None ![]() |
Was going to take the 914 out for a spin tonight (IMG:style_emoticons/default/driving.gif) and two streets from the house *POP* and engine free revs... Figured I broke an axle or something along those lines and sure enough drive side axle is no longer connected to the trans. Haven't dug in to find out if the bolts sheared or backed out but it needs fixing.
I'm planning on replacing all the CV bolts with the safety wire versions from 914 rubber and obviously safety wiring them. But should I locktite them? Antisieze? Neither? Figure I'd clean them and repack the grease, anything else while I'm under there? Might finally put the new shifter bushings I've had sitting around for eons... (Also how many are there? I think VW has 6 bolts per CV, same for our little NARP? *EDIT* 914 rubber says it right on their site, 16 total.) |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,049 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
4 bolts + 2 roll pins per CV joint.
Make sure you have the roll pins, I have found them missing on cars before |
Lo-Fi Version | Time is now: 11th March 2025 - 01:14 AM |
