> 914-4 Steering Column Bearing replacement, how I did it
chuckc
post Apr 23 2012, 10:44 PM
pete000 posted a question about 914-6 Steering Column Bearings here:
http://www.914world.com/bbs2/index.php?showtopic=182165
I have a 75 1.8 that had a lot of play in the steering column when I bought it a year ago . The PO gave me both a new steering wheel bearing and the "quick fix" sleeve/bushing that could be used in lieu of replacing the bearing. I opted to replace the bearing. Also mine didn't have a Pressure Spring or a Split Ring Bushing and I didn't have one so if this is a required item please chime in.
Tools needed:
Upper Steering Shaft Bearing, 914 1.7/1.8/2.0 (1972-76) prt# 911-347-771-02-M100
philips head
28mm socket (for steering wheel retaining nut)
breaker bar
torque wrench
5.5 metric hex wrench
needle nose pliers
3000 grit sand paper
royal purple or wd-40
Parts:
go where you'd like but you'll find 'em here w/ numbers
http://www.pelicanparts.com/catalog/shopca..._SUSstr_pg2.htm
time:
I'm slow and had a piss poor Haynes with only general steering column disassembly instructions and it took me about 4 hours to figure out while documenting. Next time will be 1 hour.
Steps:
1). remove knee pad -- 5 or 6 phillips head screws and washers on bottom. 1 small screw w/ cap on each side facing the doors.
2). remove horn, retaining nut and spring washer , and wheel. In different places I read the retaining nut was 27, 29 and 30mm, but mine was actually 28mm. final torque spec to 34 Ft-Lbs, so I used a breaker bar to loosen mine.
(I made note of where the canceling ring on the back of the wheel lined up to the steering shaft since I was also swapping wheels but keeping the canceling ring.)
3). unplug 2 electrical plugs from bottom of column (you could do this as step 2, right after you removed the knee pad)
Attached ImageAttached Image
4). remove 5.5 mm hex screw on bottom of steering column
5). remove 4 long small screws from horn contact plate and the small circ clip on the end of the shaft. Now you can pull out the wiper and indicator switch assembly enough to let it hang to the side.
Attached ImageAttached ImageAttached Image
6). remove circ clip (a b!tc# ) it sits in a groove and can be rotated out w/ needle nose or small ice picks. Then you can remove the steering shaft bearing. The guide bushing on my bearing had rotted causing the play in the shaft.
7). prior to installing the new bearing I wiped free the broken bits of plastic from the old bushing and old grease and went over the shaft quickly w/ some 3000 grit sand paper to smooth it down a bit. The new bearing fits very, very snug so I also applied a small amount of royal purple.
8). I started the bearing with my hands, then gently tapped it with a hammer just enough to get it going then used a deep socket to get it on a bit more. My socket wasn't deep enough to finish the job so I used the old bearing as a shield and tapped away with the hammer. Getting the new bearing all the way in so that the circ clip could seat properly in its' groove took some work. I ended up tapping the bearing with a small punch the last half mm.
9). use some needle nose pliers to compress the cric clip and it will snap into its' groove then just reverse the steps to get everything together. When it came time to put the retaining nut back on I had my brother in law torque it to spec while I held the steering wheel straight.
If I missed anything or screwed something up please correct me.
peace,
chuck
jim_hoyland
post Oct 26 2016, 05:31 AM
Get that VIN ?
Glad this got bumped; I'm getting ready to do this ! (IMG:style_emoticons/default/smile.gif) Question: I will replacing the the steering shaft housing too; what will it take to pull it off the shaft ?
Jett
post Oct 26 2016, 09:32 AM
I pulled the steering column, disassembled the shaft and tapped the bearing out. Took an hour to complete.
QUOTE(jim_hoyland @ Oct 26 2016, 04:31 AM) *
lennyhope
post Oct 26 2016, 01:17 PM
Region Association: England
QUOTE(Jett @ Oct 26 2016, 04:32 PM) *
HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UNDONE?
euro911
post Oct 26 2016, 05:30 PM
QUOTE(lennyhope @ Oct 26 2016, 12:17 PM) *
IIRC, this is how I did mine:
Remove the steering wheel. Remove the circlip from the shaft
Remove the lower dash pad
Unscrew the steering column support (two Allen screws)
Remove the ignition and stalk wiring plugs from behind the support
Pull the support off of the shaft
Aualexa1
post Jul 3 2020, 10:18 PM
QUOTE(euro911 @ Oct 26 2016, 05:30 PM) *
Bringing back an old thread. My wheel has a decent amount of play in all directions. A previous owner has already put the metal repair bushing, but its the actual bearing where the motion is. Trying to clarify how to remove the old bearing. Where it says "pull the support off the shaft" the "support" is the shaft cover tube and the housing. Is that correct? And when you remove those things, the bearing will come off with the shaft cover tube and then you press it out, reinstall the cover tube, and press in the new bearing?
Edit: Figured it out. The support is just the black surround piece on the steering column. Slides off with some force after undoing the Allen bolt underneath.
chuckc   914-4 Steering Column Bearing replacement   Apr 23 2012, 10:44 PM
wingnut86   Looks dead on. Good pictures and flow of your pro...   Apr 24 2012, 05:45 AM
chuckc   Looks dead on. Good pictures and flow of your pr...   Apr 24 2012, 01:39 PM
914-300Hemi   Wingnut how did you remove the old bearing?   May 10 2014, 04:29 PM
Cap'n Krusty   Wingnut how did you remove the old bearing? Yes...   Jun 17 2014, 10:04 PM
HalfMoon   Wingnut how did you remove the old bearing? Ye...   Jun 17 2014, 10:14 PM
florida 914   Wingnut how did you remove the old bearing? Ye...   Jan 14 2015, 11:26 AM
pilothyer   [quote name='Cap'n Krusty' post='2051576' dat...   Jan 14 2015, 01:04 PM
Mike Bellis   Nice write up!   May 10 2014, 05:11 PM
The Cabinetmaker   Add one more tool. Snap ring pliers.   May 10 2014, 05:35 PM
chuckc   thanks Mike. Add one more tool. Snap ring pliers...   Jun 17 2014, 07:46 PM
euro911   :agree: ... nice write-up. I need to do this on ...   Jun 17 2014, 11:39 PM
billbrip   :agree: ... nice write-up. I need to do this on...   Dec 26 2014, 07:35 AM
Cap'n Krusty   :agree: ... nice write-up. I need to do this o...   Dec 26 2014, 11:45 AM
euro911   This is going to happen pretty soon ... my igniti...   Dec 26 2014, 11:21 AM
r_towle   I did this once and removing the column from the c...   Dec 26 2014, 01:01 PM
euro911   Cross References: W0133-1632518 This Part Fits Yo...   Jan 14 2015, 03:41 PM
lennyhope   I have taken mine apart to find that someone has p...   Oct 26 2016, 03:20 AM
jim_hoyland   Glad this got bumped; I'm getting ready to do ...   Oct 26 2016, 05:31 AM
Jett   I pulled the steering column, disassembled the sha...   Oct 26 2016, 09:32 AM
lennyhope   I pulled the steering column, disassembled the sh...   Oct 26 2016, 01:17 PM
euro911   HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UND...   Oct 26 2016, 05:30 PM
jim_hoyland   HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UN...   Oct 26 2016, 05:41 PM
euro911   So it's gonna slide right up and off... :)Pre...   Oct 26 2016, 08:14 PM
jim_hoyland   So it's gonna slide right up and off... :)Pr...   Oct 26 2016, 08:23 PM
Aualexa1   HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UN...   Jul 3 2020, 10:18 PM
Aualexa1   Here’s a link to another description of this pro...   Jul 4 2020, 06:41 PM
jim_hoyland   Got a question: I have two bearings, the larger be...   Oct 27 2016, 05:11 PM
euro911   Lookie here (2) and (6)   Oct 27 2016, 05:56 PM
jim_hoyland   Hmmm.....looks like The Who assembly would have to...   Oct 27 2016, 07:35 PM
euro911   I only replaced the one closest to the steering wh...   Oct 28 2016, 01:38 AM
cassmcentee   Couple pics of mine that I just finished... Hope i...   Jul 5 2020, 07:28 AM
wolfswest   Hi, in the first post is mentioned: Upper Steerin...   Jan 23 2024, 06:32 AM
930cabman   Looks straightforward, I have been wiggling my ste...   Jan 24 2024, 11:00 AM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 01:49 AM
