messick |
Newbie ![]() Group: Members Posts: 39 Joined: 15-June 20 From: Orange, CA Member No.: 24,381 Region Association: Southern California ![]() |
So, in my quest to get my "sitting for 15 years" 914 back on the road, I've already ordered new SS tunnel lines and new rubber line for the tank side and for connecting to the fuel pump, and for the connecting back to the return line tunnel hose.
Most of the engine bay stuff is already metal (or at least not just regular rubber fuel line) and looks fine. However, the lines between the fuel distributor and the injectors themselves is just plastic. Should I replace those outright? Checking other forums, and the fact that no one seems to just sell a kit to replace those lines, gives me the impression that those should only be replaced if they are actively leaking. But, with that recent fire, I figured I'd ask here since I'm already in the middle of replacing lots of the fuel line stuff anyway. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
So, in my quest to get my "sitting for 15 years" 914 back on the road, I've already ordered new SS tunnel lines and new rubber line for the tank side and for connecting to the fuel pump, and for the connecting back to the return line tunnel hose. Most of the engine bay stuff is already metal (or at least not just regular rubber fuel line) and looks fine. However, the lines between the fuel distributor and the injectors themselves is just plastic. Should I replace those outright? Checking other forums, and the fact that no one seems to just sell a kit to replace those lines, gives me the impression that those should only be replaced if they are actively leaking. But, with that recent fire, I figured I'd ask here since I'm already in the middle of replacing lots of the fuel line stuff anyway. What engine do you have ? ,I had my fair share of experience with CIS and have never seen the stainless braided S/S ones fail but the straight plastic ones are less robust and more prone to wear but still durable if not damaged. The pure plastic lines are made of Polyamide and are fairly easy to replace if damaged,the banjo ends are barbed "push lock" fitting and reuseable so no swaging is required unlike the metal to rubber lines. Any rubber lines are prone to going hard and cracking/splitting and must be replaced and require specialist attention to replace hoses or buy new for $$$$. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:13 AM |
