Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 550 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Jul 13 2020, 07:29 PM
The lovely bunch of holes, continued:
Here's the first patch in place. The screw is used as a handle to place the patch. After the patch is tacked in place, the screw will be removed and the hole welded over. And all welded up: I'm not going to bother grinding down the welds inside the hole. No one will see them once this is all done, and they will add a little strength. I use the masking tape method to make all of the patches to replace missing metal. I'll spare you the repeated steps and just show each major step completed. Here's the third layer patch completed: The first part of the second layer patch -- re-attaching the piece that was cut out for access: And the finish of the second layer patch: That's enough for tonight. I'll tackle the outer layer patches tomorrow. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:22 PM |
