> More Rear Mount Oil Cooler Questions, Setrab Setup
BeatNavy
post Jul 6 2020, 08:47 AM
I'm trying to nail down why I'm having oil cooler issues. Specifically, I've blown two sandwich plate adapter seals in the same place / manner. In addition, during my test drives I wasn't necessarily thrilled with the temp drop I was seeing.
First, I'm running the Setrab oil cooler and Setrab sandwich plate adapter. Anyone else running the Setrab sandwich plate adapter without any issues? I know I'm not the ONLY one, but how many people run this as opposed to something like the Mocal setup?
Second, when I contacted Pegasus Racing to order more seals, I spoke to the tech guy who gave me some food for thought. The most interesting thing was he said the oil cooler needs to be mounted with the inlet and outlet ports facing up, otherwise the cooler won't fill up all the way and you won't get ideal (or any) cooling.
Here's my setup with it angled somewhat down for what I hoped was good airflow: http://www.914world.com/bbs2/index.php?s=&...t&p=2826235
Essentially he says the oil takes "the path of least resistance" which could largely be from the inlet port to the outlet port using few of the cooling rows. I assumed the pressure would fill the cooler, but I can see what he's saying. Any thoughts on that? If that's the case, I really need to completely redo my mounting setup and plumbing.
GregAmy
post Jul 13 2020, 05:06 PM
QUOTE(mepstein @ Jul 13 2020, 06:55 PM) *
Aren't the heat exchangers already a heat shield for the headers? If air is running through them, the exterior should stay pretty cool.
Mine are horribly hot, you can't even get your hands near them.
There's a TON of heat stagnating under the backside of these cars.
This is on mine. It's now covered in adhesive-backed reflective insulation.
It's finally stabilizing the temps around 215-220 (in the line exiting the cooler) on 80+ days.
Olympic 914
post Jul 13 2020, 06:28 PM
QUOTE(GregAmy @ Jul 13 2020, 07:06 PM) *
Do you still have the original oil cooler in place? No gauge sender in the taco plate?
I guess it depends where you are reading the temp.
As I understand the oil flow -
(1) its picked up from the sump,
(2) through oil pump then to the oil filter
(3) through the stock oil cooler
(4) on to the bearings etc. through the oil galley.
If you are reading the temp inline after the aux cooler your oil temp should drop some more after going through the stock cooler, before going into the engine.
Using a sandwich adapter, after the oil filter the oil goes to the aux cooler then back through the stock cooler to dissipate more heat before going to the bearings etc.
By having the sender for the temp gauge in the taco plate you are reading the oil temp after it has gone through the engine and lubricated/cooled it.
GregAmy
post Jul 14 2020, 04:57 AM
QUOTE(Olympic 914 @ Jul 13 2020, 08:28 PM) *
At the risk of diverting Rob's thread...you got me to thinking more about this.
My combo gauge and Mainely dipstick agree on temperature, so I'm pretty confident of that. I've rechecked the calibration on the R-T sensor and I have a long history of their sensors in my race cars, so I'm confident of it as well.
But here's the thing I cannot explain.
As noted I'm using the Tangerine block/thermostat and external oil cooler, and measuring the oil temperature on the outlet line of the cooler.
And yet...the temperature is the same or very similar as that in the sump.
Chris Foley and I have gone back and forth on this, and I'm very very confident that we actually have it in the cooler exit line.
But this makes no sense.
I've checked and rechecked the oil cooler lines, and rechecked the sensor calibration.
So this means that either my temp sensor is wrong, the cooler is doing nothing, and/or the ports on the thermostat block aren't what we think they are (but Chris built the block so I'm pretty sure he knows which way they go).
One thing for sure is that between adding the cooler, adding a fan to it, and ducting air to it, my oil temps are stabilizing around 215F on the Mainely dipstick at highway cruise with the fan on 100% of the time.
Everything else is up for grabs.
BeatNavy   More Rear Mount Oil Cooler Questions   Jul 6 2020, 08:47 AM
rgolia   you got two weeks to get this baby on the road and...   Jul 6 2020, 09:04 AM
BeatNavy   you got two weeks to get this baby on the road an...   Jul 6 2020, 09:10 AM
Montreal914   Yes, you are trapping air in that cooler, flip it ...   Jul 6 2020, 09:10 AM
Olympic 914   Rob Not using the Setrab sandwich adapter, So I c...   Jul 6 2020, 09:36 AM
90quattrocoupe   The most interesting thing was he said the oil co...   Jul 6 2020, 01:25 PM
BeatNavy   Thanks for the input. I spend a good part of the ...   Jul 6 2020, 03:50 PM
rmdinmd   [quote name='BeatNavy' date='Jul 6 202...   Jul 9 2020, 05:34 AM
DRPHIL914   Chris Foley mounted mine when it was up there for ...   Jul 8 2020, 06:09 AM
Porschef   :popcorn: :beer3:   Jul 9 2020, 04:54 AM
BeatNavy   Hey guys, thanks for the interest and input. We h...   Jul 9 2020, 10:32 AM
maf914   I kept pulling over to the side of the road and/o...   Jul 10 2020, 03:16 PM
Bartlett 914   Glad to read you solved the oil leaks. Would you ...   Jul 9 2020, 11:03 AM
BeatNavy   Glad to read you solved the oil leaks. Would you...   Jul 9 2020, 02:16 PM
Bartlett 914   [quote name='Bartlett 914' post='2832345' date='J...   Jul 10 2020, 07:56 AM
Olympic 914   Oh I see what you did. But going through the J-tu...   Jul 10 2020, 08:22 AM
BeatNavy   And I thought it just cluttered up the engine com...   Jul 10 2020, 08:47 AM
Bartlett 914   Oh I see what you did. But going through the J-t...   Jul 10 2020, 08:50 AM
BeatNavy   Hey Mike - interesting question. I've given i...   Jul 10 2020, 04:58 PM
stownsen914   It's good advice to have the cooler oriented w...   Jul 11 2020, 06:02 AM
BeatNavy   Remember that for an oil cooler to do its job, it...   Jul 11 2020, 06:10 AM
Porschef   Might be time to take it out for a bit of thrashin...   Jul 11 2020, 03:31 PM
Dominic   Here is a picture of my set up when I first instal...   Jul 12 2020, 10:39 AM
90quattrocoupe   Anyone thought about putting a head shield on the ...   Jul 13 2020, 02:44 PM
BeatNavy   Anyone thought about putting a head shield on the...   Jul 13 2020, 03:26 PM
mepstein   Anyone thought about putting a head shield on the...   Jul 13 2020, 04:55 PM
GregAmy   Aren't the heat exchangers already a heat shie...   Jul 13 2020, 05:06 PM
Olympic 914   [quote name='mepstein' post='2833504' date='Jul 1...   Jul 13 2020, 06:28 PM
GregAmy   Do you still have the original oil cooler in place...   Jul 13 2020, 07:35 PM
GregAmy   As I understand the oil flow - At the risk of div...   Jul 14 2020, 04:57 AM
jd74914   And yet...the temperature is the same or very sim...   Jul 14 2020, 07:29 AM
GregAmy   If you really load the thing up (say 65 mph cruisi...   Jul 14 2020, 08:12 AM
BeatNavy   At the risk of diverting Rob's thread...you g...   Jul 14 2020, 07:53 AM
Olympic 914   I've even thought about taping a cooking th...   Jul 14 2020, 09:59 AM
GregAmy   I've even thought about taping a cooking t...   Jul 15 2020, 05:53 AM
MJHanna   So Im kind of lost on all the tin you are putting ...   Jul 14 2020, 06:25 AM
MJHanna   more pics   Jul 14 2020, 06:26 AM
MJHanna   last one   Jul 14 2020, 06:27 AM
GregAmy   "No issues" meaning exactly what tempera...   Jul 14 2020, 06:44 AM
GregAmy   Rob, next time I'm driving I can shoot the IR ...   Jul 14 2020, 08:13 AM
Frank S   Rob, next time I'm driving I can shoot the IR...   Jul 15 2020, 11:10 AM
GregAmy   0, 01:10 PM' post='2834051']I had expe...   Jul 15 2020, 11:30 AM
Frank S   Thanks, Frank! Yeah, my original design had ...   Jul 15 2020, 11:49 AM
GregAmy   Did a couple things today. - Attached a flexible ...   Jul 14 2020, 04:34 PM
dirk2056   What about a different approach does the horizonta...   Jul 14 2020, 07:15 PM
Olympic 914   I did this yesterday, with the thermometer and Wif...   Jul 15 2020, 07:02 AM
GregAmy   :beer2:   Jul 15 2020, 07:08 AM
GregAmy   I have several oddball things going on, like an IG...   Jul 15 2020, 11:52 AM
Frank S   I have several oddball things going on, like an I...   Jul 15 2020, 12:27 PM
GregAmy   Is it the Ignition coil cutting out or do you str...   Jul 15 2020, 12:37 PM
Frank S   [quote name='Frank S' post='2834072' date='Jul 15...   Jul 17 2020, 01:26 AM
stownsen914   Very interesting re: the temp. under the back of t...   Jul 17 2020, 05:22 AM
GregAmy   Hi Greg, would be fine with me. But I also think i...   Jul 20 2020, 10:12 AM
VaccaRabite   That's really clean. Super impressive. I nee...   Jul 15 2020, 02:33 PM
GregAmy   Thanks. I think the vast majority of my brain powe...   Jul 15 2020, 06:10 PM
Montreal914   :popcorn: on all topics :)   Jul 15 2020, 08:08 PM
dirk2056   Cooling test under car with and w/out fans, Instal...   Jul 17 2020, 03:34 PM
Krieger   220* is a good oil temperature   Jul 17 2020, 07:44 PM
BeatNavy   Just a follow up on this thread. Did about 600 mi...   Jul 20 2020, 10:50 AM
34 User(s) are reading this topic (34 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 11:18 PM
