BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 550 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: ![]() Once I took the rockers off, I discovered this: ![]() Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,955 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Like the screw as a handle. Still had to have been fun trying to place tacks in that tight space! Maybe shoot some Eastwood Internal frame coating or something similar into that outer reinfocement to lock down the rust progression while access is easy? Photo's like this always make me laugh. No such thing as rust free 914's. You just can't see it . . . . yet. It's always lurking inside these sorts of cavities. |
BillC |
Like the screw as a handle. Still had to have been fun trying to place tacks in that tight space! Nope, not much fun at all. My legs and neck were very sore and stiff after that was all done, just from the contortions needed to make the welds. But, I was trying hard to keep the holes as small as possible. Maybe shoot some Eastwood Internal frame coating or something similar into that outer reinfocement to lock down the rust progression while access is easy? It wasn't shown, but I've been spraying rust-converter paint inside each layer right before I seal them up. I do have the Eastwood Internal Frame coating, which will be applied inside the heat tube and inside the longitudinal through the factory access holes inside the passenger compartment. Photo's like this always make me laugh. No such thing as rust free 914's. You just can't see it . . . . yet. It's always lurking inside these sorts of cavities. Someone here quipped a while ago that "rust free 914" just means the seller isn't charging for the rust. (IMG:style_emoticons/default/lol-2.gif) ( (IMG:style_emoticons/default/headbang.gif) ) |
Lo-Fi Version | Time is now: 20th June 2024 - 11:21 PM |
