More Rear Mount Oil Cooler Questions, Setrab Setup |
BeatNavy |
Jul 6 2020, 08:47 AM
Certified Professional Scapegoat Group: Members Posts: 2,938 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I'm trying to nail down why I'm having oil cooler issues. Specifically, I've blown two sandwich plate adapter seals in the same place / manner. In addition, during my test drives I wasn't necessarily thrilled with the temp drop I was seeing.
First, I'm running the Setrab oil cooler and Setrab sandwich plate adapter. Anyone else running the Setrab sandwich plate adapter without any issues? I know I'm not the ONLY one, but how many people run this as opposed to something like the Mocal setup? Second, when I contacted Pegasus Racing to order more seals, I spoke to the tech guy who gave me some food for thought. The most interesting thing was he said the oil cooler needs to be mounted with the inlet and outlet ports facing up, otherwise the cooler won't fill up all the way and you won't get ideal (or any) cooling. Here's my setup with it angled somewhat down for what I hoped was good airflow: http://www.914world.com/bbs2/index.php?s=&...t&p=2826235 Essentially he says the oil takes "the path of least resistance" which could largely be from the inlet port to the outlet port using few of the cooling rows. I assumed the pressure would fill the cooler, but I can see what he's saying. Any thoughts on that? If that's the case, I really need to completely redo my mounting setup and plumbing. |
GregAmy |
Jul 15 2020, 11:52 AM
Advanced Member Group: Members Posts: 2,397 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I have several oddball things going on, like an IGN4-VW coil that starts cutting out after 30-40 minutes. I attribute that to something different/wrong with my engine/car.
I may try adhesive-backed reflective insulation on the underside of my airbox. |
Frank S |
Jul 15 2020, 12:27 PM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
I have several oddball things going on, like an IGN4-VW coil that starts cutting out after 30-40 minutes. I attribute that to something different/wrong with my engine/car. I may try adhesive-backed reflective insulation on the underside of my airbox. Is it the Ignition coil cutting out or do you struggle with sync loss problems due to too high temps at the Crank Pic-Up Sensor? Do you have a tooth log? |
Lo-Fi Version | Time is now: 22nd November 2024 - 10:59 PM |
