Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 559 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Jul 17 2020, 04:52 PM
Time to do more work on the fuel system.
First, need to fit a new vinyl overflow tube to the gas tank (the old one was broken off too short). This was kind of a pain, since the tube has to stretch quite a bit to fit over the nipple. But, here's the result: Next, is to mount the fuel pump and fuel filter. I'm mounting them up front, and need to make sure everything will fit and clear. I'm using a Tangerine Racing fuel pump mount. I decided to also make a mount for the metal fuel filter. Here's how I did it. First, start with a strip of aluminum, 1" wide by 2.5" long and fold a "Z" bend in the middle: Then, shape one end over a socket: Here's the finished bracket: And, all the brackets mounted: I'll install fuel lines and run wires tomorrow. |
Lo-Fi Version | Time is now: 4th December 2024 - 08:14 PM |
