| RiqueMar |
Jul 18 2020, 05:11 PM
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,261 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California
For everybody out there running a GT style cooler, would you mind posting a few photos of your cooling setup and fans?
Currently re-routing my system to use a SETRAB type cooler (example here: Patrick Motorsports Website) however I don't see any reference to fans, and it doesn't seem as though it's an option to purchase. Also, appreciate any 'pointers' in the right direction when it comes to vendors that might have similar products / solutions. Thanks in advance for your help! ![]() |
| GeorgeRud |
Jul 18 2020, 07:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I think using mb911’s oil lines also help dissipate heat along their length instead of the braided hoses. My conversion just used a Turbotrol cooler in front to control temps with AN-12 lines with good results.
| sixnotfour |
Jul 18 2020, 07:49 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,065 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
I think using mb911’s oil lines also help dissipate heat along their length instead of the braided hoses. My conversion just used a Turbotrol cooler in front to control temps with AN-12 lines with good results. (IMG:style_emoticons/default/agree.gif) |
| Steve |
Jul 18 2020, 08:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,986 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I think using mb911’s oil lines also help dissipate heat along their length instead of the braided hoses. My conversion just used a Turbotrol cooler in front to control temps with AN-12 lines with good results. (IMG:style_emoticons/default/agree.gif) Depends where you live and time of year. if your six is bigger than a 2.7 and it’s over a 100 degrees outside and your stuck in traffic with no air flow, it will over heat no what setup you have. In so cal it can get up to 110 in the summer. AZ and Vegas is worse. |
| mepstein |
Jul 18 2020, 08:29 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,287 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I think using mb911’s oil lines also help dissipate heat along their length instead of the braided hoses. My conversion just used a Turbotrol cooler in front to control temps with AN-12 lines with good results. (IMG:style_emoticons/default/agree.gif) Depends where you live and time of year. if your six is bigger than a 2.7 and it’s over a 100 degrees outside and your stuck in traffic with no air flow, it will over heat no what setup you have. In so cal it can get up to 110 in the summer. AZ and Vegas is worse. That's why I decided on a fan pack. It's my only cooler. I'm using a oil cooler bypass plate on the engine. |
RiqueMar GT Cooler Question Jul 18 2020, 05:11 PM
sixnotfour Gts where fast = air flow Jul 18 2020, 05:37 PM
Retroracer Hi - so for my 2.2 six based GT tribute, I used a ... Jul 18 2020, 05:41 PM
Retroracer one more...
Jul 18 2020, 05:43 PM
mepstein 20 row Setrab with fan pack and thermostat switch.... Jul 18 2020, 05:45 PM
SirAndy I don't run any fans on mine, the only time i... Jul 18 2020, 05:46 PM
Steve Same with my 3.2. When stuck in traffic it would ... Jul 18 2020, 06:45 PM
Steve They sell a pusher and a puller fan. So depends o... Jul 18 2020, 07:04 PM
Steve
They sell a pusher and a puller fan. So depends ... Jul 20 2020, 08:54 AM
RiqueMar
They sell a pusher and a puller fan. So depends... Jul 20 2020, 10:17 AM
Steve
[quote name='Steve' post='2835460' date='Jul 20 2... Jul 21 2020, 11:24 AM
RFoulds
[quote name='Steve' post='2835460' date='Jul 20 ... Jul 21 2020, 12:39 PM
Steve
[quote name='Steve' post='2835818' date='Jul 21 2... Jul 21 2020, 01:56 PM
RiqueMar @nein14 - Curious, how much did you have to ... Jul 21 2020, 03:05 PM
ConeDodger
They sell a pusher and a puller fan. So depends... Jul 20 2020, 07:54 PM
RiqueMar Thanks everyone for the recommendations! I sho... Jul 19 2020, 08:41 PM
ConeDodger No fans on a 3.2 six. My temperatures used to be d... Jul 20 2020, 07:16 AM
Steve
No fans on a 3.2 six. My temperatures used to be ... Jul 20 2020, 08:20 AM
eric9144 PMS did fans on the floor section for mine, I only... Jul 20 2020, 01:58 PM
GregAmy Holy shit that's a gorgeous underside you have... Jul 20 2020, 03:19 PM
RiqueMar
Holy shit that's a gorgeous underside you hav... Jul 20 2020, 05:30 PM
RFoulds where can I source a shroud for front oil cooler? ... Jul 21 2020, 10:51 AM
Steve
where can I source a shroud for front oil cooler?... Jul 21 2020, 11:13 AM
RiqueMar
where can I source a shroud for front oil cooler?... Jul 21 2020, 12:13 PM
nein14 NOS RX7 oil cooler with widened GT shroud to fit c... Jul 21 2020, 01:41 PM
gereed75 Enrique, Not sure whether you have seen it or care... Jul 21 2020, 03:19 PM
Enrique, Not sure whether you have seen it or car... Jul 21 2020, 03:47 PM
rktmn247
[quote name='gereed75' post='2835877' date='Jul 2... Jul 21 2020, 07:56 PM
rgalla9146
[quote name='gereed75' post='2835877' date='Jul 2... Jul 22 2020, 08:29 AM
gereed75 Actually making it out of aluminum is not a bad id... Jul 22 2020, 06:42 AM
Actually making it out of aluminum is not a bad i... Jul 22 2020, 10:41 AM
RFoulds
Actually making it out of aluminum is not a bad ... Jul 22 2020, 10:55 AM
[quote name='mepstein' post='2836125' date='Jul 2... Jul 22 2020, 11:35 AM
RiqueMar Thanks for the continued references everyone. PMS ... Jul 23 2020, 10:36 AM
eric9144 ^^ That approach is great because it leaves you wi... Jul 22 2020, 08:43 AM
rgalla9146
^^ That approach is great because it leaves you w... Jul 22 2020, 08:56 AM
Marv's3.6six Here is my system which is a Patrick Motorsports S... Jul 22 2020, 09:28 AM
Marv's3.6six System with Getty CF lid installed. Jul 22 2020, 09:40 AM
eric9144
You've still got a rear trunk right ? man th... Jul 22 2020, 09:49 AM
RFoulds I like the shroud that vents out the side, but min... Jul 22 2020, 10:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 05:18 AM |
