FS various bits 1 of 3, misc parts |
dangrouche |
Jul 17 2020, 01:43 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
UPDATE July 20, 2020. Thanks all for buying up these parts from this posting. It's been a while since I listed stuff for sale and did not realize that worn CVs do not have a market, and therefore I am removing them and the pics from this listing.
Prices do not include shipping. I ship by the Postal Service from California zip 94005 (suburb outside of San Francisco) and accept PayPal. NO international shipping. Private mail (PM) what you want and provide me your zip code, then I will pack it into smallest box possible and weigh the purchase and use the postal website to figure the cheapest way possible with tracking. I will PM the amount owed (items + postage owed). PayPal me as a friend and I’ll ship it out and provide you tracking after I’ve shipped from the post office. lthough the stuff is listed pretty cheaply, postage may exceed cost of the item, so buy up a load of stuff (marketing here ) and I’ll put it in a USPS flat rate box or parcel post it. Your post of what you want is a “soft commitment” so the rest of the board that the item is spoken for and I will “line out” on the post that the item is sold. C Oil filter mount $8 D G relay board stud $2 B1 glove box lid $5 B2 bumper dog bone $1 B3 passenger headlight motor cover $3 B4 square to round transition for blower motor $3 B5 passenger wiper arm $3 B6 driver door lid spring $1 CV joint #3 CV joint #4 D2 drain (does not have crack on either ear) with tube $2 D4 rear brake shield mount (pair) $2 D5 accelerator pedal cover coated coated with POR15 $3 D6 accelerator pedal board washer coated with POR15 $2 Driver A housing $8 Driver B housing $8 Passenger A tail light housing $8 Passenger B tail light housing $8 E1 fuel sender(has been disassembled and determined to be fully operational) $20 E2 front signal housing bracket $1 E3 bicycle derailleur cables for thermostat (two available) $1 each G1 tray $2 G2 tray $2 J1 battery ground cable $2 J3 set of five VW hubcaps J4 early gas cap (NEEDS total rebuild/rebuild of soft rubber parts on the underside) $2 K1 fabricated oil cooler relocation kit K2 defroster knob $2 K4 fabricated glove box shelf white $3 O USED pair of tie rod ends $8 P surface rusted master cylinder reservoir strap $3 R driver quality Hella lens (has fracture crack) $3 T MPS untested $4 V MPS untested $4 |
frostyf |
Jul 19 2020, 02:48 PM
Member Group: Members Posts: 155 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Hi if they've not gone can I take :
J - ECU Clamp (if it fits 2.0l ECU); F1 - rubber rings pliable and untorn; Q - engine compt light? Could you let me know if these are available or if they've already gone. Thank you, Nick J ECU bracket, with DEFECT F1 set of three rubber rings for console gauges (all perfect and pliable and untorn) $8 Q engine compartment light housing (not cracked) $3 |
dangrouche |
Jul 19 2020, 09:35 PM
Hi if they've not gone can I take : J - ECU Clamp (if it fits 2.0l ECU); F1 - rubber rings pliable and untorn; Q - engine compt light? Could you let me know if these are available or if they've already gone. Thank you, Nick J ECU bracket, with DEFECT F1 set of three rubber rings for console gauges (all perfect and pliable and untorn) $8 Q engine compartment light housing (not cracked) $3 they are yours ! |
Lo-Fi Version | Time is now: 24th September 2024 - 12:59 PM |
