WTB, 2.0 air cleaner bracket, coil bracket, fan shroud flap, warm air guide, for '72 side shift conversion. |
eyesright |
Jul 24 2020, 02:04 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
I have a very nice '72. I have built up a 1911 and put in a rebuilt side shift transmission. Here are a few odd parts I need.
Fan shroud flap, (the small cheap aluminum ones on the bottom) passenger side #921119263A. I have the small one for the driver's side. I need the bigger one, passenger side. 2.0 air cleaner bracket. I'm using a 2.0 L throttle body to go with the 3 bolt heads from HAM and found a good air cleaner on my shelf...but need a bracket to mount it to the throttle body. Coil bracket. I donated mine to a -6 conversion thinking it would be forever before I got this car built. Forever is here and I need a replacement. Warn air guide for a tail shifter conversion. I'll be installing the exhaust and heater boxes next week and I've heard the passenger side warm air guide is the same but the driver's side is different. Can anybody help? I can paypal. Please PM me. Thanks everybody. |
Craigers17 |
Jul 24 2020, 02:25 PM
Senior Member Group: Members Posts: 785 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
I have a very nice '72. I have built up a 1911 and put in a rebuilt side shift transmission. Here are a few odd parts I need. Fan shroud flap, (the small cheap aluminum ones on the bottom) passenger side #921119263A. I have the small one for the driver's side. I need the bigger one, passenger side. 2.0 air cleaner bracket. I'm using a 2.0 L throttle body to go with the 3 bolt heads from HAM and found a good air cleaner on my shelf...but need a bracket to mount it to the throttle body. Coil bracket. I donated mine to a -6 conversion thinking it would be forever before I got this car built. Forever is here and I need a replacement. Warn air guide for a tail shifter conversion. I'll be installing the exhaust and heater boxes next week and I've heard the passenger side warm air guide is the same but the driver's side is different. Can anybody help? I can paypal. Please PM me. Thanks everybody. On the 2.0 air cleaner....are you looking for the clamp that goes around the air box that tightens down over the throttle body or the actual bracket that mounts to the driver's side runners, and then clamps to the box? |
eyesright |
Jul 24 2020, 04:24 PM
On the 2.0 air cleaner....are you looking for the clamp that goes around the air box that tightens down over the throttle body or the actual bracket that mounts to the driver's side runners, and then clamps to the box? [/quote] I have the 2.0 air cleaner complete with the circular clamp to the throttle body, all the wire clamps on top and the 2 wire clamps on the bottom. So, yes, I need the actual bracket that mounts to the driver's side intake runners that the bottom wire clamps...ah...clamp to. Thanks for the clarification. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:43 AM |
