eyesright |
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region ![]() |
I have a very nice '72. I have built up a 1911 and put in a rebuilt side shift transmission. Here are a few odd parts I need.
Fan shroud flap, (the small cheap aluminum ones on the bottom) passenger side #921119263A. I have the small one for the driver's side. I need the bigger one, passenger side. 2.0 air cleaner bracket. I'm using a 2.0 L throttle body to go with the 3 bolt heads from HAM and found a good air cleaner on my shelf...but need a bracket to mount it to the throttle body. Coil bracket. I donated mine to a -6 conversion thinking it would be forever before I got this car built. Forever is here and I need a replacement. Warn air guide for a tail shifter conversion. I'll be installing the exhaust and heater boxes next week and I've heard the passenger side warm air guide is the same but the driver's side is different. Can anybody help? I can paypal. Please PM me. Thanks everybody. |
Craigers17 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 756 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States ![]() ![]() |
I have a very nice '72. I have built up a 1911 and put in a rebuilt side shift transmission. Here are a few odd parts I need. Fan shroud flap, (the small cheap aluminum ones on the bottom) passenger side #921119263A. I have the small one for the driver's side. I need the bigger one, passenger side. 2.0 air cleaner bracket. I'm using a 2.0 L throttle body to go with the 3 bolt heads from HAM and found a good air cleaner on my shelf...but need a bracket to mount it to the throttle body. Coil bracket. I donated mine to a -6 conversion thinking it would be forever before I got this car built. Forever is here and I need a replacement. Warn air guide for a tail shifter conversion. I'll be installing the exhaust and heater boxes next week and I've heard the passenger side warm air guide is the same but the driver's side is different. Can anybody help? I can paypal. Please PM me. Thanks everybody. On the 2.0 air cleaner....are you looking for the clamp that goes around the air box that tightens down over the throttle body or the actual bracket that mounts to the driver's side runners, and then clamps to the box? |
eyesright |
On the 2.0 air cleaner....are you looking for the clamp that goes around the air box that tightens down over the throttle body or the actual bracket that mounts to the driver's side runners, and then clamps to the box? [/quote] I have the 2.0 air cleaner complete with the circular clamp to the throttle body, all the wire clamps on top and the 2 wire clamps on the bottom. So, yes, I need the actual bracket that mounts to the driver's side intake runners that the bottom wire clamps...ah...clamp to. Thanks for the clarification. |
Craigers17 |
[quote name='eyesright' date='Jul 24 2020, 04:24 PM' post='2836801']
2.0 air cleaner bracket. I'm using a 2.0 L throttle body to go with the 3 bolt heads from HAM and found a good air cleaner on my shelf...but need a bracket to mount it to the throttle body. On the 2.0 air cleaner....are you looking for the clamp that goes around the air box that tightens down over the throttle body or the actual bracket that mounts to the driver's side runners, and then clamps to the box? [/quote] I have the 2.0 air cleaner complete with the circular clamp to the throttle body, all the wire clamps on top and the 2 wire clamps on the bottom. So, yes, I need the actual bracket that mounts to the driver's side intake runners that the bottom wire clamps...ah...clamp to. Thanks for the clarification. [/quote] I have a well used bracket if you're interested. It's missing two of the little rubber stoppers on one side and another is cracked, but I think you could find some hardware store plugs of some sort to pop in those holes. Otherwise, it just needs some TLC. I have included some pics. If you want it, just PM me your name and address and I'll put it in the mail tomorrow. If you want to hold out for something better, I get it. No worries. Just let me know. ![]() ![]() ![]() |
eyesright |
I have a well used bracket if you're interested. It's missing two of the little rubber stoppers on one side and another is cracked, but I think you could find some hardware store plugs of some sort to pop in those holes. Otherwise, it just needs some TLC. I have included some pics. If you want it, just PM me your name and address and I'll put it in the mail tomorrow. If you want to hold out for something better, I get it. No worries. Just let me know. ![]() ![]() ![]() [/quote] Wow, such a deal. I can make that work. PM forthcoming. One part done. Thankyou. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@eyesright
It is missing some of the rubber pads that cushion the air box. They are the same as the headlight eyebrow grommets sold by 914 Rubber. You probably need to replace all of them as they get hard. |
Lo-Fi Version | Time is now: 24th June 2024 - 11:40 PM |
