> D-Jet Fuel Injection Pulse Phasing
Not_A_Six
post Jul 15 2020, 04:51 PM
Hi All-
I recently installed a 123Ignition dizzy in my '73 2.0. It apparently can be installed in any of 4 orientations, in 90 degree increments and operate properly when wired to the plugs appropriately.
The d-jet version of the 123 dizzy also has two wires that are used to time the two groups of fuel injection pulses (cyl 1+4 and 3+2). These wires can be connected to the ECU in either polarity, and the "correct" polarity to time/phase the injection pulses seems to depend upon both the distributor orientation, and the wire polarity. Instructions from 123 Ignition show a connector sketch that "suggests" a particular polarity, but I think the correct one also depends on the chosen dizzy orientation, as well as the firing order. (The dizzy can be used in non-914 applications. E.g., with a straight 4.)
I'm an EE. I've been through Paul Anders' ( @pbanders ) very helpful writeups on the ECU and d-jet operation. I've got d-jet schematics. And, I've got a generic (Volvo?) chart purporting to show the injection timing WRT the cylinders (which seems to have a lot of discrepancies with a 914 setup with different firing order.) I've also looked at the injection pulse/spark timing with an oscilloscope (with a high-v probe).
It looks like the orientation and polarity can be adjusted to inject fuel at any of the following times:
1) Inject cylinders 1 and 3 during intake stroke and cylinders 4 and 2 during exhaust stroke.
2) Inject cylinders 1 and 3 during power stroke and cylinders 4 and 2 during compression stroke.
3) Inject cylinders 1 and 3 during exhaust stroke and cylinders 4 and 2 during power stroke.
4) Inject cylinders 1 and 3 during compression stroke and cylinders 4 and 2 during intake stroke.
I think the choice of the 4 options above would affect the dwell time of the fuel charge in the intake runners and might also cause some raw fuel to be sent out the exhaust if a pulse occurs during valve overlap.
Which of the 4 configurations is correct? Is my analysis correct, or did I miss something? Any other advice you can give me?
Thanks for your help.
Cheers. (IMG:style_emoticons/default/beerchug.gif)
rjames
post Jul 16 2020, 07:38 PM
I'm made of metal
I have a 123dizzy and wasn’t able to get idle rpms below 1000 using either the advance of retard settings and at least one other person here had the same experience, IIRC. If you can’t get below 1500, something else is wrong. How was your idle before installing the 123?
Have you checked the throttle body air bleed screw? Sounds like a vacuum leak or timing is off.
Not_A_Six
post Jul 16 2020, 07:46 PM
QUOTE(rjames @ Jul 16 2020, 06:38 PM) *
I have a 123dizzy and wasn’t able to get idle rpms below 1000 using either the advance of retard settings and at least one other person here had the same experience. That said, if you can’t get below 1500, something else is wrong. How was your idle before installing the 123?
Thanks for your comment.
The whole idle/retard discussion is kind of tangential to the original FI phasing questions that I started the thread for.
Nevertheless, it's interesting, and may be helpful to somebody else down the road.
I *can* get it to idle just fine at around 1000 rpm with the 123 vac retard connected and profile "A". With profile "1", I couldn't get it below 1500 rpm. I figure that under idle conditions (no centrifugal advance, throttle plate closed) that profile "A" gives a net idle timing of -5 degrees (which matches OEM) and profile "1" gives a net timing of +5 degrees. I attribute the elevated idle with profile "1" to that difference in timing. But, I don't rule out that something else may be in play (e.g. an undetected vacuum leak as has been mentioned.)
FWIW, this is not a stock engine. It's a 2056 with a webcam 73 cam. But, I don't believe this is the primary cause of the high idle with the vac advance profile.
Frank S
post Jul 17 2020, 12:55 AM
Region Association: Germany
You want to use vac advance with this engine. Setting #2 the engine likes to idle between 950 and 1000 RPM with 10° to 12° BTDC at that engine speed. If the RPM's are to high you probably have a vacuum leak or running to rich. Did you try to lean out the idle mixture?
Not_A_Six
post Jul 17 2020, 10:35 AM
QUOTE(Frank S @ Jul 16 2020, 11:55 PM) *
Thanks, I'll try #2 out. I have the Tangerine kit installed to adjust the MPS, and I've tuned the AFR with an wideband O2 meter. (Yes, I know about the idle mixture knob on the ECU. And, I have the TPS adjusted properly...)
In a bit of an update for anybody searching/reading this in the future, I contacted 123 to find the start and end pressures for the "A" (retard) profile as that information is missing from their instructions for all of the retard profiles.
Their response: "For vacuum retard, the customer needs to rotate the ignition by 10 degrees to retard the ignition. The ignition has the following vacuum map: The retard starts at 80mmhg (3.2 in-Hg) and ends at 150mmhg (5.9 in-Hg) with 10 degrees."
When connected to the retard port on the throttle body, I think this should operate the way I want -- retard 10 degrees at high vacuum at idle, and transition to zero advance/retard as the throttle plate opens and the throttle plate moves below the retard port, causing low to zero vacuum at that port.
But, I wonder if there is some venturi effect at the retard port under part-throttle conditions. If so, the 123 "A" profile may be causing some undesired vacuum retard above idle, but under low load.
Nevertheless, I think that those here chanting "Vacuum Leak" were right after all. I've replaced every hose and gasket, and removed every component to pull a vac on it and test. So far I haven't been able to find it. I'm gonna hook it up to a smoke machine next week and see if I missed something. (Maybe I have a hairline crack in the intake plenum or one of the peened fittings there is leaking...)
My plan now is to find a leak, then switch back to profile #1 (or #2) with vac advance.
Thank you to all who responded.
Cheers.
Not_A_Six
post Jul 31 2020, 03:35 PM
Update for anybody interested:
A special thanks to @JeffBowlsby ! Using his information, I've been able to set up the 123 pulse phasing to match the OEM design, and confirmed with an oscilloscope. It feels like there may be a slight difference in driveability depending on how the FI phasing is set up, but it may be entirely my imagination. The effect seems subtle, if it matters at all.
I did a smoke test to look for vacuum leaks, and it appears that everything is tight. So, I'm now suspicious that the PCV valve is worn and flowing more air than it should (even after cleaning), causing the high idle problem with the 123 "1" profile.
The OEM PCV valve is impossible to find (for me anyway...). And, I'm reluctant to just plumb the PCV to the airbox as was apparently done on later-year models. So, I'm currently in the process of adapting a modern Toyota PCV valve as a replacement. If the Toyota PCV works, I'll start a thread about it as it might be useful to others.
Cheers.
Not_A_Six   D-Jet Fuel Injection Pulse Phasing   Jul 15 2020, 04:51 PM
914_teener   I installed the 123 with stock D jet as shown per ...   Jul 15 2020, 05:31 PM
Not_A_Six   I installed the 123 with stock D jet as shown per...   Jul 15 2020, 05:39 PM
JeffBowlsby   If I recall, DJet squirts a 50% charge in two batc...   Jul 15 2020, 06:59 PM
Not_A_Six   If I recall, DJet squirts a 50% charge in two bat...   Jul 15 2020, 07:13 PM
Not_A_Six   If I recall, DJet squirts a 50% charge in two bat...   Jul 15 2020, 09:56 PM
JeffBowlsby   Sounds good. Hence the need for two 50% fuel char...   Jul 15 2020, 10:40 PM
Not_A_Six   Sounds good. Hence the need for two 50% fuel cha...   Jul 16 2020, 09:23 AM
JeffBowlsby   The trigger points contain 2 switches which each i...   Jul 16 2020, 10:38 AM
Not_A_Six   The trigger points contain 2 switches which each ...   Jul 16 2020, 11:44 AM
914_teener   Added plus with the electronic dizzy is the elimin...   Jul 16 2020, 09:22 AM
Not_A_Six   Added plus with the electronic dizzy is the elimi...   Jul 16 2020, 09:58 AM
914_teener   Added plus with the electronic dizzy is the elim...   Jul 16 2020, 11:04 AM
Not_A_Six   Thanks! Yeah, the 123 dizzy looks pretty s...   Jul 16 2020, 12:16 PM
914_teener   [quote name='914_teener' post='2834348' date='Jul...   Jul 16 2020, 05:54 PM
Not_A_Six   Yes....I believe you are missing something. Fir...   Jul 16 2020, 06:54 PM
GregAmy   Bosch D-Jetronic is "batch injection". ...   Jul 16 2020, 12:02 PM
Not_A_Six   Bosch D-Jetronic is "batch injection". ...   Jul 16 2020, 12:20 PM
rjames   I have a 123dizzy and wasn’t able to get idle rp...   Jul 16 2020, 07:38 PM
Not_A_Six   I have a 123dizzy and wasn’t able to get idle r...   Jul 16 2020, 07:46 PM
Frank S   FWIW, this is not a stock engine. It's a 2056...   Jul 17 2020, 12:55 AM
Not_A_Six   FWIW, this is not a stock engine. It's a 205...   Jul 17 2020, 10:35 AM
Not_A_Six   Update for anybody interested: A special thanks t...   Jul 31 2020, 03:35 PM
914_teener   [quote name='Frank S' date='Jul 16 202...   Jul 17 2020, 04:25 PM
Not_A_Six   ...And so you would ajust the static timing and ru...   Jul 17 2020, 06:31 PM
914_teener   The ported vacuum is not "disabled". Tha...   Jul 16 2020, 08:02 PM
Not_A_Six   The ported vacuum is not "disabled". Th...   Jul 16 2020, 08:07 PM
ctc911ctc   THIS THREAD IS MASTER CLASS! :beer2: :head...   Jul 17 2020, 07:43 PM
pbanders   IMO, if there's a choice on the 123 between va...   May 21 2021, 04:21 PM
- Lo-Fi Version Time is now: 4th April 2025 - 12:43 PM
