bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
These are the parts that weld to the interior floor cross member. The passenger side is needed when a fixed seat is replaced with a movable seat. When the cross member is replaced these need to be removed from the old cross member and welded into the new cross member.
I have about a dozen of each side made. Bracket cost is $20 each for left or right or a pair for $35. Combs are $12 each, two for $20. Bundle of two combs and two brackets with hardware $50 Bolts pictured are too long. For illustration only. @914LTD @Cary Attached image(s) ![]() ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Awesome.
I'll take a pair of the brackets assuming the $35 is shipped, that will save me some fab time down the road. Pet peeve - (IMG:style_emoticons/default/dead horse.gif) I know fasteners were for illustrative purpose, but, ditch the lockwashers they are literally worthless and serve no locking function whatsoever. Plain washer - (IMG:style_emoticons/default/biggrin.gif) lockwasher (IMG:style_emoticons/default/sad.gif) I know . . I'm a jackass! Thanks for making these! Do you prefer F&F or purcase good for shipping via Paypal? |
bdstone914 |
@Superhawk996
I'll take a pair of the brackets assuming the $35 is shipped, that will save me some fab time down the road. Pet peeve - (IMG:style_emoticons/default/dead horse.gif) I know fasteners were for illustrative purpose, but, ditch the lockwashers they are literally worthless and serve no locking function whatsoever. Plain washer - (IMG:style_emoticons/default/biggrin.gif) lockwasher (IMG:style_emoticons/default/sad.gif) I know . . I'm a jackass! Thanks for making these! Do you prefer F&F or purcase good for shipping via Paypal? [/quote] Yes $35 shipped. Do NOT send as F & F. My pet peeve. It removes your address, eliminates the shipping discount and does not save the seller on small dollar buys like this. I am interested why you say lock washers are worthless. You are not a jackass. I respect your knowledge as an engineer. I know who the jackasses are on this board. I have the correct length bolts on order. Should be to me on Monday. Will provide flat washers. I normally like to provide the same hardware as OE or better. |
Superhawk996 |
I am interested why you say lock washers are worthless. You are not a jackass. I respect your knowledge as an engineer. Very kind words (IMG:style_emoticons/default/biggrin.gif) but I'm OK with being a jackass sometimes. (IMG:style_emoticons/default/happy11.gif) Best explained by NASA fastener design manual. ![]() https://snebulos.mit.edu/projects/reference...ASA-RP-1228.pdf Within automotive they are not used on modern cars for the follwing reasons: 1) They add huge variability to fastener torque and clamp load within the joint. Any critical joint is now secured by a DC nut-runner that usually monitors torque and angle within a narrowly defined set of upper and lower spec limits. Lockwashers just screw all that up. If the nutrunner doesn't achieve proper torque and angle the part or assembly is rejected into a repair area for root cause identification and/or rework. Repairs cost $ and degrade first time though process capability (i.e. thoughput). 2) They don't add any locking effect (per NASA) as confirmed in a multitude of automotive applications where they have been studied since I first came into the industry decades ago. 3) As a separate part, they are prone to being left out / forgotten. If a washer is required, captive washers are now the norm for error proofing reasons. 4) They sometimes fail (i.e. crack) and then vibrate out from under the fastener head - now you have a loose joint without any clamp load. 5) OEM's don't like to give away parts for "free" that perform no function Paypal sent. Thanks for making these Bruce, I wasn't looking forward to making my own. These are a great deal at $35 vs. my time to layout from scratch, cut, drill, etc. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:28 PM |
