I need help with rear trunk torsion bar, How do I get the bar behind the roller? |
Doug Leggins |
Oct 4 2005, 08:55 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
The teener kicked my ass tonight! I simply wore myself out trying to get the rear trunk torsion bar behind the trunk roller.
I searched for as much info as I cold find before beginning this task. I modified my 12" adjustable wrench as mentioned on other threads on this topic. This tool proved to be a very good lever for pushing the torsion bar back. I could get the torsion bar pushed/twisted back well enough but I could not get it around the hinge roller/pin. I tried several times but could not find a way to get the roller behind the pin on the hinge. I tried to remove the hinge then hold the torsion bar back as far as I could and then reinstall the hinge -This is the task the wore me out! No matter how or what I tried I could not find a way to get the bar behind the roller. Anyone know the secret/technique to get the torsion bar in place? Here is a pic of the wrench with a notch cut out on the end. Attached image(s) |
Arno914 |
Aug 27 2020, 06:25 AM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
Place some thick cushioning on the area where the torsion spring might impact in case it slips off the socket while you try to pry it over the roller pin. Otherwise it will leave a big ding on your bodyshell! (IMG:style_emoticons/default/headbang.gif)
These springs are nothing for kids... (IMG:style_emoticons/default/dry.gif) |
