Lilchopshop |
Member ![]() ![]() Group: Members Posts: 75 Joined: 17-February 20 From: New York Member No.: 23,932 Region Association: North East States ![]() |
I have a 73 2.0L that came to me with an aftermarket turbo and no heat exchangers or heater boxes. I want to put the motor back to stock, so I'm looking for the original air cleaner, throttle body, intake hoses and heat exchangers, heater control boxes, muffler, etc. Most of the stuff that's shown below. I could also use some good engine cooling tin since mine was cut up for the turbo by the PO. Willing to look at whatever you have that would fit 2.0L motor with Engine # GA001100.
Attached image(s) ![]() ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@Lilchopshop
I see missing the air filter, air filter bracket assembly, throttle body, throttle position, boot for air filter to throttle body. Bad passenger side top tin and front corner tin. I have those parts. I can post pictures as I get them rounded up. Have you done a compression or leak down test on the engine to see if has a chance of running without rebuild ? |
Lilchopshop |
@Lilchopshop I see missing the air filter, air filter bracket assembly, throttle body, throttle position, boot for air filter to throttle body. Bad passenger side top tin and front corner tin. I have those parts. I can post pictures as I get them rounded up. Have you done a compression or leak down test on the engine to see if has a chance of running without rebuild ? Yes please!!!! I haven’t done compression or leak testing yet but plan to. Knowing how I approach things, I will probably do a complete rebuild anyway. Thinking about going to a 2056 with stock FI. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:34 AM |
