> New Fuel Line suggestions, Expert opinions needed for safety.
ri914
post Aug 31 2020, 06:26 PM
Ok, got the gas tank out last night.
Going to run 2 new steel lines. My plan was to use 3/8 for both lines and place a small low pressure pump under the tank to feed the 60psi pump back near the LS motor.
Is it safe to run all low pressure fuel hoses and connections to and from the tank? I was planning on using 6AN connections for the high pressure line from the big pump to the motor?
thoughts and suggestions are greatly appreciated.
thank you
ChrisFoley
post Sep 1 2020, 08:52 AM
I am Tangerine Racing
QUOTE(ri914 @ Aug 31 2020, 08:26 PM) *
Consider using pre-bent stainless lines (made by a nearby vendor) in the tunnel. Use Gates Barricade (or similar) high pressure hose, even in the low pressure parts of the system.
Tangerine Racing Fuel System Page
- Lo-Fi Version Time is now: 6th January 2025 - 03:11 PM
