New Fuel Line suggestions, Expert opinions needed for safety. |
ri914 |
Aug 31 2020, 06:26 PM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
Ok, got the gas tank out last night.
Going to run 2 new steel lines. My plan was to use 3/8 for both lines and place a small low pressure pump under the tank to feed the 60psi pump back near the LS motor. Is it safe to run all low pressure fuel hoses and connections to and from the tank? I was planning on using 6AN connections for the high pressure line from the big pump to the motor? thoughts and suggestions are greatly appreciated. thank you Attached thumbnail(s) |
ChrisFoley |
Sep 1 2020, 08:52 AM
I am Tangerine Racing Group: Members Posts: 7,970 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... Going to run 2 new steel lines. ... Is it safe to run all low pressure fuel hoses and connections to and from the tank? ... Consider using pre-bent stainless lines (made by a nearby vendor) in the tunnel. Use Gates Barricade (or similar) high pressure hose, even in the low pressure parts of the system. Tangerine Racing Fuel System Page |
cary |
Sep 1 2020, 10:08 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
... Going to run 2 new steel lines. ... Is it safe to run all low pressure fuel hoses and connections to and from the tank? ... Consider using pre-bent stainless lines (made by a nearby vendor) in the tunnel. Use Gates Barricade (or similar) high pressure hose, even in the low pressure parts of the system. Tangerine Racing Fuel System Page Near By Vendor, too funny. |
ChrisFoley |
Sep 2 2020, 03:40 PM
Near By Vendor, too funny. Close enough that he can come here to pick them up if he wants. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 6th January 2025 - 03:27 PM |
