Master Cylinder Installation, 2 Quick Questions |
Craigers17 |
Sep 18 2020, 03:22 PM
Senior Member Group: Members Posts: 800 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
So I'm in the processing of re-installing my master cylinder, brakes etc. I had to take the 90 degree fitting off of the old master cylinder & use on the new one. My questions are:
1. Is there a washer or gasket that goes between the main M/C body and the fitting or just a washer between the 2 parts of the fitting? 2. There is a hole for the fluid to flow through in both the fitting body and the piece that pivots around it, for each of the front brakes. My question is do these 2 holes have to line up? My guess is they don't, but just wanted to double check before I install this beast....I really don't want to do this twice. I hope I have explained this accurately,...I'm just referring to the front brake splitter for lack of a better term, ...not the feed lines to the reservoir. I do realize that I need a washer below the rubber grommets where the feed lines go. Thanks for your help. |
Craigers17 |
Sep 19 2020, 08:23 AM
Thanks for the replies and information gentlemen! Very helpful...this is what I needed to know.
....while I do try to consult the manual and Tech tips books first, as well as the search features, sometimes the experience and knowledge of the folks on this forum is invaluable. It is very much appreciated! (IMG:style_emoticons/default/beerchug.gif) |
stownsen914 |
Sep 19 2020, 01:41 PM
Senior Member Group: Members Posts: 930 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
As mentioned above, you do need washers on both sides of the banjo fitting. I prefer to use new ones since they do deform. They should be standard sizes in case they're NLA or expensive from Porsche.
Lo-Fi Version | Time is now: 24th November 2024 - 01:28 AM |
