> Master Cylinder Installation, 2 Quick Questions
Craigers17
post Sep 18 2020, 03:22 PM
So I'm in the processing of re-installing my master cylinder, brakes etc. I had to take the 90 degree fitting off of the old master cylinder & use on the new one. My questions are:
1. Is there a washer or gasket that goes between the main M/C body and the fitting or just a washer between the 2 parts of the fitting?
2. There is a hole for the fluid to flow through in both the fitting body and the piece that pivots around it, for each of the front brakes. My question is do these 2 holes have to line up? My guess is they don't, but just wanted to double check before I install this beast....I really don't want to do this twice.
I hope I have explained this accurately,...I'm just referring to the front brake splitter for lack of a better term, ...not the feed lines to the reservoir. I do realize that I need a washer below the rubber grommets where the feed lines go. Thanks for your help.
IronHillRestorations
post Sep 20 2020, 09:32 AM
I. I. R. C.
The aluminum are for oil line fittings. I’d only use the copper ones for the brake line fittings. I can see some value in anealing the exhaust copper gaskets, but I don’t think it’s necessary for sealing rings
Craigers17
post Sep 20 2020, 11:21 AM
QUOTE(IronHillRestorations @ Sep 20 2020, 09:32 AM) *
Perry, Bruce, & Stownsen914,
Thanks for the additional info! Embarrassingly enough, I found the second washer under a crusty coat of dirt and rust .... still attached to the old MC. At least now I know exactly what size both washers are.
On a crappier note, while trying to wrestle the new M/C onto the reservoir lines, I tore one of the 2 rubber grommets...so I'll need to grab a couple of those before this proceeds any further.....what a pain in the ass this job is. After further reconsideration, I think I'm going to take out the gas tank, and replace the reservoir & the feed lines too. That way I can get these lines fitted into the M/C first, and then feed them up to the reservoir as noted in another post......live and learn.....
RichPugh
post Sep 20 2020, 07:55 PM
Thats the move. I have my tank out currently to get the fresh air blower motor fan working (sucessfully did that today) and next is to tackle replacing the stock MC w/ a 19mm. working under the car trying to fit the MC to the hoses, SUCKS.
Craigers17   Master Cylinder Installation   Sep 18 2020, 03:22 PM
mankowski   I don't think the MC's come new with those...   Sep 18 2020, 04:36 PM
mepstein   @Eric_Shea :beer2:   Sep 18 2020, 06:08 PM
Craigers17   Thanks for the responses. I think I'm over-an...   Sep 18 2020, 06:37 PM
ri914   Thanks for the responses. I think I'm over-a...   Sep 18 2020, 06:54 PM
bdstone914   Yes you need a crush washer on both sides of the v...   Sep 19 2020, 07:30 AM
ri914   Yes you need a crush washer on both sides of the ...   Sep 19 2020, 08:06 AM
Craigers17   Thanks for the replies and information gentlemen...   Sep 19 2020, 08:23 AM
stownsen914   As mentioned above, you do need washers on both si...   Sep 19 2020, 01:41 PM
IronHillRestorations   Yes you need a copper sealing ring on both sides o...   Sep 19 2020, 07:00 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 20 2020, 08:14 AM
IronHillRestorations   The aluminum are for oil line fittings. I’d only...   Sep 20 2020, 09:32 AM
Craigers17   The aluminum are for oil line fittings. I’d onl...   Sep 20 2020, 11:21 AM
RichPugh   Thats the move. I have my tank out currently to ...   Sep 20 2020, 07:55 PM
VaccaRabite   Thats the move. I have my tank out currently to...   Sep 21 2020, 01:05 PM
Eric_Shea   10x16 and 14x16 Copper Gaskets go on the banjo bol...   Sep 25 2020, 05:03 PM
Craigers17   10x16 and 14x16 Copper Gaskets go on the banjo bo...   Sep 26 2020, 03:27 AM
ndfrigi   10x16 and 14x16 Copper Gaskets go on the banjo bo...   Sep 30 2020, 03:58 PM
MartyYeoman   The best way I've found to install the two res...   Sep 26 2020, 07:48 PM
Craigers17   The best way I've found to install the two re...   Sep 27 2020, 04:22 AM
Craigers17   Got the m/c and pedal cluster installed. I still ...   Sep 27 2020, 12:19 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 02:07 AM
