> Master Cylinder Installation, 2 Quick Questions
Craigers17
post Sep 18 2020, 03:22 PM
So I'm in the processing of re-installing my master cylinder, brakes etc. I had to take the 90 degree fitting off of the old master cylinder & use on the new one. My questions are:
1. Is there a washer or gasket that goes between the main M/C body and the fitting or just a washer between the 2 parts of the fitting?
2. There is a hole for the fluid to flow through in both the fitting body and the piece that pivots around it, for each of the front brakes. My question is do these 2 holes have to line up? My guess is they don't, but just wanted to double check before I install this beast....I really don't want to do this twice.
I hope I have explained this accurately,...I'm just referring to the front brake splitter for lack of a better term, ...not the feed lines to the reservoir. I do realize that I need a washer below the rubber grommets where the feed lines go. Thanks for your help.
Eric_Shea
post Sep 25 2020, 05:03 PM
PMB Performance
10x16 and 14x16 Copper Gaskets go on the banjo bolts 14x16 under the head and 10x16 under the banjo and on the MC side.
Craigers17   Master Cylinder Installation   Sep 18 2020, 03:22 PM
mankowski   I don't think the MC's come new with those...   Sep 18 2020, 04:36 PM
mepstein   @Eric_Shea :beer2:   Sep 18 2020, 06:08 PM
Craigers17   Thanks for the responses. I think I'm over-an...   Sep 18 2020, 06:37 PM
ri914   Thanks for the responses. I think I'm over-a...   Sep 18 2020, 06:54 PM
bdstone914   Yes you need a crush washer on both sides of the v...   Sep 19 2020, 07:30 AM
ri914   Yes you need a crush washer on both sides of the ...   Sep 19 2020, 08:06 AM
Craigers17   Thanks for the replies and information gentlemen...   Sep 19 2020, 08:23 AM
stownsen914   As mentioned above, you do need washers on both si...   Sep 19 2020, 01:41 PM
IronHillRestorations   Yes you need a copper sealing ring on both sides o...   Sep 19 2020, 07:00 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 20 2020, 08:14 AM
IronHillRestorations   The aluminum are for oil line fittings. I’d only...   Sep 20 2020, 09:32 AM
Craigers17   The aluminum are for oil line fittings. I’d onl...   Sep 20 2020, 11:21 AM
RichPugh   Thats the move. I have my tank out currently to ...   Sep 20 2020, 07:55 PM
VaccaRabite   Thats the move. I have my tank out currently to...   Sep 21 2020, 01:05 PM
Eric_Shea   10x16 and 14x16 Copper Gaskets go on the banjo bol...   Sep 25 2020, 05:03 PM
Craigers17   10x16 and 14x16 Copper Gaskets go on the banjo bo...   Sep 26 2020, 03:27 AM
ndfrigi   10x16 and 14x16 Copper Gaskets go on the banjo bo...   Sep 30 2020, 03:58 PM
MartyYeoman   The best way I've found to install the two res...   Sep 26 2020, 07:48 PM
Craigers17   The best way I've found to install the two re...   Sep 27 2020, 04:22 AM
Craigers17   Got the m/c and pedal cluster installed. I still ...   Sep 27 2020, 12:19 PM
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 02:12 AM
