Master Cylinder Installation, 2 Quick Questions |
Craigers17 |
Sep 18 2020, 03:22 PM
Senior Member Group: Members Posts: 800 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
So I'm in the processing of re-installing my master cylinder, brakes etc. I had to take the 90 degree fitting off of the old master cylinder & use on the new one. My questions are:
1. Is there a washer or gasket that goes between the main M/C body and the fitting or just a washer between the 2 parts of the fitting? 2. There is a hole for the fluid to flow through in both the fitting body and the piece that pivots around it, for each of the front brakes. My question is do these 2 holes have to line up? My guess is they don't, but just wanted to double check before I install this beast....I really don't want to do this twice. I hope I have explained this accurately,...I'm just referring to the front brake splitter for lack of a better term, ...not the feed lines to the reservoir. I do realize that I need a washer below the rubber grommets where the feed lines go. Thanks for your help. |
Eric_Shea |
Sep 25 2020, 05:03 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
10x16 and 14x16 Copper Gaskets go on the banjo bolts 14x16 under the head and 10x16 under the banjo and on the MC side.
Craigers17 |
Sep 26 2020, 03:27 AM
Lo-Fi Version | Time is now: 24th November 2024 - 02:06 AM |
