Confirming Fuel Line routing, Fuel lines 1974 2.0 |
simonjb |
Sep 26 2020, 11:03 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Hi,
I just want to confirm my fuel lines as I have now converted to a 2 port fuel pump from a 3 as I rebuild my original 2.0 Djet system. The diagram below and others seem to confirm... Tank to Filter to Pump to Fuel Rail (Cylinder 3&4) to second Fuel Rail (cylinder 1&2) to Pressure Regulator to Return Tank line. Then a separate line off the (cylinder 1&2) Fuel Rail to the CSV. Correct? |
iankarr |
Sep 26 2020, 01:12 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,522 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Yep. Only difference between 3 port and 2 port is with 2 port the return line from the fuel pressure regulator goes right to the tank return, instead of the pump port.
Lo-Fi Version | Time is now: 26th November 2024 - 05:58 AM |
