MSD Distributor / Ignition Set -up |
David Mueller |
Dec 20 2004, 02:59 PM
Member Group: Members Posts: 79 Joined: 4-February 03 From: Calgary, Alberta Canada Member No.: 236 |
I've a '74 2.0L which is running a MSD6A ignition system and I just bought (not installed yet) a MSD Distributor to replace the stock unit. The car is running 96MM big bore kit from EBS racing, dual 44MM weber's and a MSD Blaster II coil - etc...
Has anyone got some recommendations on the advance spring settings for the MSD 8485... Also what about the sheet metal around the distributor am I going to have to cut to make it fit ? The car was running well with the optical pick-up (Crane 7000) but I guess I'll pull that out when I install the new distributor - Sounds like a good winter afternoon project ..... |
Mueller |
Dec 20 2004, 03:05 PM
Dave,
I'm pretty sure no cutting, the tin can be "persuaded" to move out of the way with a hammer (ball peen) |
Lo-Fi Version | Time is now: 18th June 2024 - 05:13 AM |
