Main Targa Seal Install, A/K/A Defeated by rubber |
johnlush |
Mar 28 2019, 05:56 PM
What's all this then? Group: Members Posts: 372 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains |
After way too many hours on this I'm out of ideas. Yes, I've searched and it looks like struggling with the installation of the main targa seal is part of the game but it is possible. That has not been my experience. I got the right a-pillar portion installed by sliding it down from the top although everything I've read said that wouldn't work and to seat the inside lip in the channel and work the outer lip into the trim with a suitable tool. So far so good and off to the left side. Nothing and I mean nothing works. Tried sliding from the top and it binds about a third of the way in and will go no further. I've already examined the track for dings and crud and it's clean and mostly straight. So I give up on that idea and decide OK, let's do the one lip at a time thing. I can't get it to start using anything I try. I have flat nylon tools, screwdrivers, putty knives, you name. it.
I've heard it alluded to that there are pictures and/or videos of how the #%^& to do this but I can't find them. Any words of wisdom would be greatly appreciated... |
Mikey914 |
Sep 28 2020, 02:10 PM
The rubber man Group: Members Posts: 12,736 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Even f you are missing the tab, you can make adjustments by anchoring the corners with the screw that holds it and starting the section on the track side and pulling to set the angle where it's correct before doing the entire track.
Mark |
chandler1969 |
Sep 28 2020, 02:48 PM
Member Group: Members Posts: 112 Joined: 2-January 06 From: Georgetown, Ky Member No.: 5,352 Region Association: None |
Even f you are missing the tab, you can make adjustments by anchoring the corners with the screw that holds it and starting the section on the track side and pulling to set the angle where it's correct before doing the entire track. Mark Thanks! I was thinking the same but knowing I have never done this, thought I would ask. |
Lo-Fi Version | Time is now: 28th November 2024 - 10:47 PM |
