jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
The new 914 Rubber headlight adjusters with back-block just arrived; Will I have to re-aim the headlights ? Or can I R/R without ?
@Mikey914 Attached image(s) ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@jim_hoyland
date='Sep 29 2020, 07:43 AM' post='2855229'] The new 914 Rubber headlight adjusters with back-block just arrived; Will I have to re-aim the headlights ? Or can I R/R without ? @Mikey914 [/quote] If you measure the distance the screw extends thru the block and reset to about the sane distance you should be close. Do tgem one at a time. |
jim_hoyland |
[quote name='bdstone914' date='Sep 29 2020, 03:47 PM' post='2855375']
@jim_hoyland date='Sep 29 2020, 07:43 AM' post='2855229'] The new 914 Rubber headlight adjusters with back-block just arrived; Will I have to re-aim the headlights ? Or can I R/R without ? @Mikey914 [/quote] If you measure the distance the screw extends thru the block and reset to about the sane distance you should be close. Do tgem one at a time. [/quote] That was a helpful idea... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:01 PM |
