Another Master Cylinder Reservoir headache thread, Hose fittings would have been nice, porsche |
betz |
Oct 22 2020, 10:14 AM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
I did a lot of searching but none really have quite the same issue I'm having.
So I installed a new master cylinder a while back, wrestled around with the reservoir flared fittings into the grommets, etc etc, finally got it in somehow. FYI- this is a URO parts master cylinder. I am wary of URO parts not always being the best quality but the @UROpartsman seems to stand behind their products and makes revisions based on feedback so I trust it well enough. So anyways, got it installed, but it was leaking just small little drops from the reservoir fitting towards the front of the car. Enough to drain the reservoir overnight. Did some searching and saw that many people forget the washers. But also see the Uro master cylinder has them pre-installed as of a recent revision. I take the safe road and buy a couple of washers, right part number genuine porsche. Pull out my master cyl again, pull out the grommets, of course it already had washers in there. Since I got this far I replaced the washers anyways, and reinstall everything. NOW, it doesn't drip drop. It's a constant stream, leaking like a sieve. Front fitting again, the back one if it leaks, doesn't leak nearly as much. I wrestle with the fittings even more and may have gotten it down to a profuse drop. But the fittings were pushed all the way into the cylinder as far as I could tell! No amount of wrestling got them any further. And I was pushing into it pretty hard. Seems like maybe the angle had an effect on how much it was leaking. But is it really to the point that you need to just get them in just perfect or else it will leak? Seems like normal driving could move it around. I would think it's just, if it's in it's in. My solution for now is I guess I'll buy new grommets? I'm just wondering if there's any case that that the flare fitting is only partially seated, or did I just wrestle with it too much and somehow damage the grommets? How can I tell it's seated? Anyways I got some Ate brand grommets on the way since that's the only thing I could think of causing the leak. Would appreciate any insight, thanks. |
betz |
Oct 22 2020, 06:53 PM
Hopefully this helps someone out, but I measured the length of the grommet to be 0.664" on my calipers.
Took out my master again, I don't know per se if this is the issue, but it looks like my (front) grommet has some damage - maybe from putting it in and out? I didn't use any tools on it and wasn't really overly aggressive taking it out but this is how it looks. Thinking I'm best off replacing it either way: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1603414415.1.jpg) And not entirely sure what the discussion above is about but this is what the top of my master looks like... (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1603414416.2.jpg) |
UROpartsman |
Oct 23 2020, 09:12 AM
Member Group: Members Posts: 292 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
Took out my master again, I don't know per se if this is the issue, but it looks like my (front) grommet has some damage - maybe from putting it in and out? The lip in the bore is beveled on top to make it easier to insert the grommets, but it's quite sharp on the bottom edge (since the grommets are consumables and aren't meant to be removed and reinstalled), so removing the grommets could scrape them like that. We do sell Master Cylinder Reservoir Grommet 901 355 929 00 separately, and would be happy to send you a pair so you can start fresh. We'll send you a PM. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:19 AM |
