> 123 Distributor / Setting timing
rjames
post Oct 25 2020, 03:43 PM
I'm made of metal
For those that have a 123 Distributor, I need some help setting my timing. I'm probably over thinking all of this but I've read several different threads on setting the timing with this distributor and I have interpreted them all differently.
I'm running a stock 2.0 w/ DJet.
The 123 distributor setting I'm using is 'B' (negative advance), and has a max advance of 22 @ 2700 RPM.
With my new-school timing light that allows me to set the advance, (with vacuum line from the tb plugged) do I:
- Set timing light to 27 advance and rev to 3500 RPM and time to the TDC mark?
- Set timing light to 0 advance and rev to 3500 RPM and time to 27 degree mark (same as above, right?)
- Set timing light to 22 advance and rev to 2700 RPM and time to TDC mark?
- Something else? (IMG:style_emoticons/default/rolleyes.gif)
I feel like an idiot asking this question. Timing is such a basic thing and I had no problem with the stock distributor and an old school timing light, but I've read more than one thread on how to time with the 123 distributor, plus I've also read that there's 10 degrees advance added at static on these distributors.
Help!
914_teener
post Oct 25 2020, 08:57 PM
Make sure you are using ported vacum from the throttle body for vac advance and not manifold vacum.
rjames
post Oct 26 2020, 12:19 AM
I'm made of metal
QUOTE(914_teener @ Oct 25 2020, 07:57 PM) *
I’m using setting ‘B’ on the distributor which uses manifold vacuum to retard the advance at idle with a TB that only has the retard port.
rjames   123 Distributor / Setting timing   Oct 25 2020, 03:43 PM
michael7810   You are looking for total advance w/o the vacuum a...   Oct 25 2020, 04:09 PM
DRPHIL914   For those that have a 123 Distributor, I need som...   Oct 25 2020, 04:45 PM
rjames   Thanks Phil. I’ve read that thread several times...   Oct 25 2020, 05:52 PM
DRPHIL914   Thanks Phil. I’ve read that thread several time...   Oct 25 2020, 06:07 PM
rjames   Thanks Phil. I’ve read that thread several tim...   Oct 25 2020, 08:46 PM
914_teener   Make sure you are using ported vacum from the thro...   Oct 25 2020, 08:57 PM
rjames   Make sure you are using ported vacum from the thr...   Oct 26 2020, 12:19 AM
914_teener   Make sure you are using ported vacum from the th...   Oct 26 2020, 11:21 AM
DRPHIL914   [quote name='DRPHIL914' post='2861781' date='Oct ...   Oct 25 2020, 09:10 PM
914_teener   Post a picture looking down the throttle body and ...   Oct 26 2020, 11:28 AM
rjames   Post a picture looking down the throttle body and...   Oct 26 2020, 12:57 PM
rjames   -   Oct 26 2020, 04:58 PM
914_teener   So I'm confused. The original dizzy on the 91...   Oct 26 2020, 08:07 PM
rjames   I have the vacuum port on the dizzy connected to t...   Oct 26 2020, 11:16 PM
914_teener   I have the vacuum port on the dizzy connected to ...   Oct 27 2020, 12:35 PM
rjames   I have the vacuum port on the dizzy connected to...   Oct 27 2020, 01:32 PM
914_teener   [quote name='914_teener' post='2862162' date='Oct...   Oct 27 2020, 02:40 PM
DRPHIL914   hey 914 teener, what curve did you run? “ I...   Oct 27 2020, 05:35 PM
914_teener   hey 914 teener, what curve did you run? “ I...   Oct 28 2020, 11:56 AM
DRPHIL914   @rjames [b]@[url=http://www.914world.com/bbs2/in...   Nov 2 2020, 07:23 AM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 05:12 PM
