123 Distributor / Setting timing |
rjames |
Oct 25 2020, 03:43 PM
I'm made of metal Group: Members Posts: 4,141 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
For those that have a 123 Distributor, I need some help setting my timing. I'm probably over thinking all of this but I've read several different threads on setting the timing with this distributor and I have interpreted them all differently.
I'm running a stock 2.0 w/ DJet. The 123 distributor setting I'm using is 'B' (negative advance), and has a max advance of 22 @ 2700 RPM. With my new-school timing light that allows me to set the advance, (with vacuum line from the tb plugged) do I: - Set timing light to 27 advance and rev to 3500 RPM and time to the TDC mark? - Set timing light to 0 advance and rev to 3500 RPM and time to 27 degree mark (same as above, right?) - Set timing light to 22 advance and rev to 2700 RPM and time to TDC mark? - Something else? (IMG:style_emoticons/default/rolleyes.gif) I feel like an idiot asking this question. Timing is such a basic thing and I had no problem with the stock distributor and an old school timing light, but I've read more than one thread on how to time with the 123 distributor, plus I've also read that there's 10 degrees advance added at static on these distributors. Help! |
914_teener |
Oct 25 2020, 08:57 PM
914 Guru Group: Members Posts: 5,248 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Make sure you are using ported vacum from the throttle body for vac advance and not manifold vacum.
rjames |
Oct 26 2020, 12:19 AM
914_teener |
Oct 26 2020, 11:21 AM
Make sure you are using ported vacum from the throttle body for vac advance and not manifold vacum. I’m using setting ‘B’ which uses manifold vacuum to retard the advance at idle with a tb that only has the retard port. What year is your Throttle body? Post 73? |
Lo-Fi Version | Time is now: 24th November 2024 - 05:06 PM |
