Update : Electrical Nightmare : 1 issue left, trace gremlins or start over |
ri914 |
Oct 21 2020, 07:52 AM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
Ever have the fuel pump kick on when you turn on the marker lights? how about the headlights deciding to work sporadically coupled with no brake lights or turn signals...
Not sure this is worth trying to track or chase down. I have all the wiring diagrams and everything matches, so I know i have the correct wires. I am thinking my headlight switch is bad and possibly a few other items. I am thinking it might be easier to rewire these functions but willing to give it a few more tries if anyone has been down this road before. Any thoughts or good threads I should study? thank you So many helpful fixes, down to 1 thing left, the turn signals, detailed diagnosis on my last post... |
lierofox |
Oct 27 2020, 02:40 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Brake light switch and turn signals, when the hazard switch knob is pushed in, should receive power from Fuse 9 (on with key On.)
Hazard switch switches over to Fuse 11 (always hot) instead when the knob is pulled out. Are you testing this with the key switched to On? Also, have you pulled down the fuse panel to make sure the spade connectors on the back of the block are plugged in, tight, and free from corrosion? (I'm guessing all of the above is good since you mentioned you've been able to get the brake lights working.) You can try pulling out the hazard switch and probe terminal 15 with the knob pushed in to make sure there's 12v going there, as well as terminal 49. Try taking a look at the wiring going up the steering column to the turn signal stalk, if you peek under the lower dash pad, double check to make sure the connectors there are firmly pushed in all the way. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:01 PM |
