MM1 |
914 obsession continues ![]() ![]() ![]() Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California ![]() ![]() |
SKF vs FAG
I thought I read recently that some of you have had issues with newer FAG bearings vs SKF - can you please comment? With that tip I tried to buy SKF's (which were made in Italy) from one of our favorite suppliers recently, but received - from their supplier - a chinese bearing in an SKF (made in Italy) box. Stuff happens, so no issues with one of our favorite suppliers . . . you know who you are - we thank you! (IMG:style_emoticons/default/pray.gif) I'll be attempting this replacement myself (IMG:style_emoticons/default/unsure.gif) , so I don't want to do this again in 6 months, so should I insist on tracking down real SKF's? Are the older SKF's made in Germany and more reliable (and available from 'Teeners)? |
Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,503 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
Yes, Timken makes a correct bearing. Another good choice. Timken 513106 Yes, Timken makes a correct bearing. Another good choice. Timken 513106 Thanks, Mark - I wonder if it’s made in the good ol’ U.S. of A? The Timkens add at Amazon has a review from 2017 w/ pics from a Boxter owner where he broke a new set open to find lubrication issues. https://www.amazon.com/Timken-513106-Wheel-...customerReviews . |
MM1 |
Yes, Timken makes a correct bearing. Another good choice. Timken 513106 Yes, Timken makes a correct bearing. Another good choice. Timken 513106 Thanks, Mark - I wonder if it’s made in the good ol’ U.S. of A? The Timkens add at Amazon has a review from 2017 w/ pics from a Boxter owner where he broke a new set open to find lubrication issues. https://www.amazon.com/Timken-513106-Wheel-...customerReviews . Thank you - notice the picture of the item is FAG with red seal. Btw - this brings up another question: I thought I read on an older thread that one of our most active members suggested opening new rear wheel bearings and using a proper grease (don't remember what that was) . . .would you all consider that? Makes sense on a 100k bearing - but I would be afraid to rip a seal . . . |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,381 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Yes, Timken makes a correct bearing. Another good choice. Timken 513106 Yes, Timken makes a correct bearing. Another good choice. Timken 513106 Thanks, Mark - I wonder if it’s made in the good ol’ U.S. of A? The Timkens add at Amazon has a review from 2017 w/ pics from a Boxter owner where he broke a new set open to find lubrication issues. https://www.amazon.com/Timken-513106-Wheel-...customerReviews . Thank you - notice the picture of the item is FAG with red seal. Btw - this brings up another question: I thought I read on an older thread that one of our most active members suggested opening new rear wheel bearings and using a proper grease (don't remember what that was) . . .would you all consider that? Makes sense on a 100k bearing - but I would be afraid to rip a seal . . . I did just that... here's my thread when I did it. I felt that my bearings did not have enough grease in them... (IMG:style_emoticons/default/stirthepot.gif) http://www.914world.com/bbs2/index.php?sho...=337345&hl= |
MM1 |
Yes, Timken makes a correct bearing. Another good choice. Timken 513106 Yes, Timken makes a correct bearing. Another good choice. Timken 513106 Thanks, Mark - I wonder if it’s made in the good ol’ U.S. of A? The Timkens add at Amazon has a review from 2017 w/ pics from a Boxter owner where he broke a new set open to find lubrication issues. https://www.amazon.com/Timken-513106-Wheel-...customerReviews . Thank you - notice the picture of the item is FAG with red seal. Btw - this brings up another question: I thought I read on an older thread that one of our most active members suggested opening new rear wheel bearings and using a proper grease (don't remember what that was) . . .would you all consider that? Makes sense on a 100k bearing - but I would be afraid to rip a seal . . . I did just that... here's my thread when I did it. I felt that my bearings did not have enough grease in them... (IMG:style_emoticons/default/stirthepot.gif) http://www.914world.com/bbs2/index.php?sho...=337345&hl= Thanks, Luke - yep that's the thread I (partially) read. I truly appreciate information and opinions from you all - both sides help inform my decision (but they are waaaay better/trustworthy than reading reviews on Amazon - and a hundred times more fun). |
Lo-Fi Version | Time is now: 28th June 2024 - 02:11 PM |
