Aluminum Dial Trim Rings for Gauges |
rothaus |
Sep 30 2020, 10:49 AM
Member Group: Members Posts: 119 Joined: 20-November 10 From: Virginia Member No.: 12,404 Region Association: None |
Now in stock, Dial rings for 914 Gauges.
carmagic.us (IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1601484559.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1601484559.2.jpg) Available for early style gauges (IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1601484559.3.jpg) Late style gauges (IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1601484560.4.jpg) Thanks Engelbert |
914werke |
Nov 2 2020, 01:05 PM
"I got blisters on me fingers" Group: Members Posts: 10,946 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
The rings for the 3 main gauges holding mechanically, and can be removed if needed. Can you elaborate? (IMG:style_emoticons/default/biggrin.gif) Do I pry off & replace or do they snap over my existing OE rings? |
rothaus |
Nov 3 2020, 07:10 AM
The rings for the 3 main gauges holding mechanically, and can be removed if needed. Can you elaborate? (IMG:style_emoticons/default/biggrin.gif) Do I pry off & replace or do they snap over my existing OE rings? Here from the instructions: After removing the new rings from the package, try each ring on the gauge rings for fitment. At this point they will be loose. Remove the rings and go to next step. Next: Use a small screw driver to roll the edge of the trim ring slightly so a hook will be created. Do this for all the way around the edge. See picture. Be careful and just do it very light and test fit. If it’s still lose and will not click in, repeat it until the ring clicks in and sits firm. Thanks Engelbert |
Lo-Fi Version | Time is now: 26th November 2024 - 05:43 AM |
