Rikyrat |
Member ![]() ![]() Group: Members Posts: 58 Joined: 30-January 19 From: Phoenix Member No.: 22,844 Region Association: None ![]() |
EGADS, tuning my megasquirt fi system, is driving me nervous.
If anybody has and would wiling to share tune files with me, I would be very appreciative. As that would allow me to compare it with mine Thank you in advance |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Good info from Jeff. From what I've heard alpha-N may be the way to go with ITB's. I actually ran Alpha-N on mine for a while (it's a stock 2.0 throttle body/manifold), and it ran pretty well. I just didn't seem to be getting a strong enough vacuum at idle to make idle fine-tuning possible. This is related to my second comment... ...don't put TOO much stock in type 4 AFR readings at idle. You MAY get something useful, or you may not, depending on a number of factors. I was crazy rich when my AFR showed crazy lean, and that had me chasing my tail with VE values and other settings for a long time. My point is use other inputs besides AFR at idle to determine the best tune. I should have trusted my instincts earlier. Yeah, tell us more about your setup. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:55 AM |
