FL000 |
Member ![]() ![]() Group: Members Posts: 444 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California ![]() ![]() |
Hi World, I am moving on to the next phase of my project, and have enough things planned that I will call it phase 2. Hopefully this thread will motivate me to see it through quicker, and maybe help someone else at the same time.
Phase 1 was my 7 year adventure taking a banged up 73 roller and installing a SBC, renegade kit, and Sheridan body kit. Here is basically what it looks like now ![]() Had fun driving it for a summer and a winter, then realized I am ready to start the next round of upgrades. The list in no particular order and consists of: Heat and a/c Audi 01E install Fuel injection Boxster brakes Fix passenger door gap Time and money varies, so no timeline for when it will get done, but my wife's 62 Lincoln is next in line so I do have some encouragement to finish! |
FL000 |
Well that sucks. Got passenger long reinforcement welded in with gap set as desired and this was the result with weight on wheels. Not sure how evident it is from picture, but gap closed up quite a bit. No more rubbing so I guess that is good.
Door is functional so going to put problem to back burner again. Short of a frame bench I think a roll cage may be my only at home solution at this point. Don’t really want a roll cage so need to ponder on it for awhile. The longs do the majority of the work keeping the door gap set, so I wonder if my flex is happening in the metal above it, with the shock being the lever to bend it all forward. (IMG:style_emoticons/default/idea.gif) Attached image(s) ![]() ![]() |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Well that sucks. Got passenger long reinforcement welded in with gap set as desired and this was the result with weight on wheels. Not sure how evident it is from picture, but gap closed up quite a bit. No more rubbing so I guess that is good. Door is functional so going to put problem to back burner again. Short of a frame bench I think a roll cage may be my only at home solution at this point. Don’t really want a roll cage so need to ponder on it for awhile. The longs do the majority of the work keeping the door gap set, so I wonder if my flex is happening in the metal above it, with the shock being the lever to bend it all forward. (IMG:style_emoticons/default/idea.gif) How is the front gap? It is possible to shift the door forward slightly, with a bit of persuasion of the B-pillar hinge mount spots (with a block and hammer and feeling brave). |
Lo-Fi Version | Time is now: 2nd April 2025 - 06:49 PM |
