Mcraneiowa |
Member ![]() ![]() Group: Members Posts: 82 Joined: 16-June 20 From: IA Member No.: 24,387 Region Association: None ![]() |
Took my passenger Outer door handle off to degrease as it was pulling pretty hard before releasing the door to open. After cleaning it now seems to pull a bit harder than before. What did I do wrong?
steuspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest ![]() |
remove the latch mechanism. That is what gets dirty and gummed up. Soak in degreaser cleaner pb blaster etc..
Mcraneiowa |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,580 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
remove the latch mechanism. That is what gets dirty and gummed up. Soak in degreaser cleaner pb blaster etc.. Thanks, I’ll pull that tomorrow and give it a good cleaning. Don't forget to lube it back up before re-installation. Clay |
MM1 |
914 obsession continues ![]() ![]() ![]() Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California ![]() ![]() |
remove the latch mechanism. That is what gets dirty and gummed up. Soak in degreaser cleaner pb blaster etc.. Thanks, I’ll pull that tomorrow and give it a good cleaning. Don't forget to lube it back up before re-installation. Clay What is you preferred lube for door/frunk latches? |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:22 PM |
