914nb |
Newbie ![]() Group: Members Posts: 34 Joined: 5-August 20 From: Northamptonshire, UK. Member No.: 24,569 Region Association: England ![]() |
Hi all,
Iv just put a battery on my new 914 to try and identify a fuel leak as declared by the previous owner. Im guessing a test with low compressed air and carbon cleaner shouldn't leave bubbles coming from the plug terminals or from around the yellow cap/ metal housing? Thanks Nathan |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Hi all, Iv just put a battery on my new 914 to try and identify a fuel leak as declared by the previous owner. Im guessing a test with low compressed air and carbon cleaner shouldn't leave bubbles coming from the plug terminals or from around the yellow cap/ metal housing? Thanks Nathan That should work. Operating pressure is 32psi. They should handle 60 for test purposes. |
914nb |
[quote name='bdstone914' date='Nov 22 2020, 09:51 AM' post='2868443']
[quote name='914nb' post='2868428' date='Nov 22 2020, 08:12 AM'] Hi all, Iv just put a battery on my new 914 to try and identify a fuel leak as declared by the previous owner. Im guessing a test with low compressed air and carbon cleaner shouldn't leave bubbles coming from the plug terminals or from around the yellow cap/ metal housing? Thanks Nathan [/quote] That should work. Operating pressure is 32psi. They should handle 60 for test purposes. Thanks for clarification, unfortunately I have all 4 injectors leaking, not something I was expecting when the previous owner had the injectors rebuilt and only had around a thousand miles on them. Just found the starter is seized solid too! After some work I had it firing out but the motor won't turn |
Lo-Fi Version | Time is now: 24th June 2024 - 11:22 PM |
