Ansbacher |
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 ![]() |
The clutch pedal on my '74 2.0 is too close to me. I want to adjust it forward but cannot budge the shaft. I have loosened the retaining nut but I cannot spin the shaft forward. There is plenty of threads to make an adjustment but it will not turn. I cannot get a good grip on the shaft with any tool because it is round and I don't want to grab the pedal shoe for fear of breaking it off. Tried PB Blaster, but no effect. How the hell do I get this thing loose??? Ideas appreciated.
Ansbacher |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@Ansbacher
You may need to remove the pedal set to break loose the clutch pedal. I clamp them in a vise so the jaws go both above and below the bend. I then rock the pedal set to break it loose. You are only going to get about 1" more distance. You could make a custom pedal by cutting out a section of the shaft. I can supply a clutch pedal if you go that route. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:33 PM |
