> Oil Catch Can?
RolinkHaus
post Nov 23 2020, 04:43 AM
Wondering if a Oil Catch Can is worth it?
How does it effect the cooling properties? Good possibility I will track the car in the future.
GregAmy
post Nov 23 2020, 11:52 AM
If you're putting anything 200TW or stickier on a Type 4 engine, you really need dry sump...
But, if you insist anyway, the tuna can isn't really enough volume for extended g-forces; you really need an extended sump.
http://www.autoatlanta.com/Porsche-Deep-Su...PN-RMIS300.html
I've got two of a different style I'm not likely to use, since the race car has a dry sump. The street car, which may see a TrackNight or two, is on Firehawk A/S tires...
Charles Freeborn
post Nov 25 2020, 04:42 AM
QUOTE(GregAmy @ Nov 23 2020, 09:52 AM) *
Mine has an accusump. Agreed not as good as dry sump, but a step in the right direction.
RolinkHaus   Oil Catch Can?   Nov 23 2020, 04:43 AM
RolinkHaus   Found some info. http://www.914world.com/bbs2/inde...   Nov 23 2020, 05:04 AM
GregAmy   Catch cans are required by most racing orgs to kee...   Nov 23 2020, 07:51 AM
brant   If you put the car onto a track You need an oil p...   Nov 23 2020, 08:02 AM
RolinkHaus   If you were buying a tuna can which one would you ...   Nov 23 2020, 10:39 AM
brant   I haven't really looked very closely at what i...   Nov 23 2020, 11:13 AM
ChrisFoley   I have not looked to see if CFR sells one I h...   Nov 23 2020, 02:32 PM
GregAmy   If you're putting anything 200TW or stickier o...   Nov 23 2020, 11:52 AM
Charles Freeborn   If you're putting anything 200TW or stickier ...   Nov 25 2020, 04:42 AM
brant   [quote name='GregAmy' post='2868767' date='Nov 23...   Nov 25 2020, 09:37 AM
ThePaintedMan   I ran an accusump on a type 4 for around 10 yea...   Nov 25 2020, 11:43 AM
Charles Freeborn   [quote name='GregAmy' post='2868767' date='Nov 2...   Nov 25 2020, 06:05 PM
RolinkHaus   Chris Foley ....Pm'd you   Nov 23 2020, 06:40 PM
RolinkHaus   Looking for this catch can. Pic posted by Kargeek...   Nov 29 2020, 06:02 PM
914werke   I haven't really looked very closely at what ...   Nov 29 2020, 08:08 PM
RolinkHaus   I haven't really looked very closely at what...   Nov 30 2020, 04:43 AM
914werke   Do you have a pic? Of which the Old Welt. versio...   Nov 30 2020, 10:47 AM
RolinkHaus   Yeah, already have one of these. Looking for a oi...   Nov 30 2020, 07:27 PM
GregAmy   I'd love to find a catch can that completely r...   Dec 2 2020, 05:29 PM
Jetsetsurfshop   :driving:   Dec 2 2020, 08:38 PM
Jetsetsurfshop   This is Rev's VW Bug. Jake built the engine fo...   Dec 2 2020, 08:40 PM
GregAmy   So they inserted a bracket/bar across the void and...   Dec 2 2020, 09:32 PM
RolinkHaus   Being that I have a late 1975 does it require a PC...   Dec 3 2020, 05:36 AM
RolinkHaus   In order for the oil catch can (oil breather) to w...   Dec 6 2020, 06:59 AM
GregAmy   The air filter provides no significant vacuum to t...   Dec 6 2020, 08:39 AM
RolinkHaus   Thank you!!   Dec 6 2020, 08:42 AM
GregAmy   Quick correction: I got to re-thinking and just lo...   Dec 6 2020, 10:00 AM
RolinkHaus   Mine has a K&N.   Dec 6 2020, 11:51 AM
brant   A breather box should not be mounted low Also th...   Dec 6 2020, 12:20 PM
Charles Freeborn   Here is mine. Mounts to the cross bar on engine si...   Dec 7 2020, 09:05 PM
stownsen914   Here is mine. Looks like an electric fan setup....   Dec 9 2020, 07:18 AM
Charles Freeborn   Here is mine. Looks like an electric fan setup...   Dec 9 2020, 10:02 AM
ChrisFoley   No need to drill holes thru the sides of the tower...   Dec 8 2020, 09:41 AM
GregAmy   No need to drill holes thru the sides of the towe...   Dec 8 2020, 11:02 AM
ChrisFoley   No need to drill holes thru the sides of the tow...   Dec 8 2020, 12:23 PM
GregAmy   When the aluminum block is rotated into position, ...   Dec 8 2020, 01:03 PM
Jetsetsurfshop   No need to drill holes thru the sides of the towe...   Dec 9 2020, 01:04 PM
Charles Freeborn   Chris' flat fan set up is a thing of beauty. T...   Dec 10 2020, 09:45 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 11:40 AM
