> Oil Catch Can?
RolinkHaus
post Nov 23 2020, 04:43 AM
Wondering if a Oil Catch Can is worth it?
How does it effect the cooling properties? Good possibility I will track the car in the future.
GregAmy
post Nov 23 2020, 11:52 AM
If you're putting anything 200TW or stickier on a Type 4 engine, you really need dry sump...
But, if you insist anyway, the tuna can isn't really enough volume for extended g-forces; you really need an extended sump.
http://www.autoatlanta.com/Porsche-Deep-Su...PN-RMIS300.html
I've got two of a different style I'm not likely to use, since the race car has a dry sump. The street car, which may see a TrackNight or two, is on Firehawk A/S tires...
Charles Freeborn
post Nov 25 2020, 04:42 AM
QUOTE(GregAmy @ Nov 23 2020, 09:52 AM) *
Mine has an accusump. Agreed not as good as dry sump, but a step in the right direction.
brant
post Nov 25 2020, 09:37 AM
QUOTE(Charles Freeborn @ Nov 25 2020, 03:42 AM) *
I ran an accusump on a type 4 for around 10 years of wheel to wheel racing
they work fine... I never ran a dry sump -4 to compare to.
the tuna can is cheap and easy for Driver education or autox
I would not be concerned about using a tuna can alone on a track with less than dedicated race tires. Especially for someone just starting out, or Drivers Education type of setting.
the accusump is better on slick race tires and long sweeping corners
I ran a 2nd Oil pressure sender in the front trunk oil cooler system
with the 2nd warning light, you could see the pressure drop well before the factory sender ever warned.
you could easily see when you forgot to open the accusump, and the difference once it was opened.
they tend to blow valve cover gaskets... if you spin or kill the motor and dump too much oil into the block.
RolinkHaus   Oil Catch Can?   Nov 23 2020, 04:43 AM
RolinkHaus   Found some info. http://www.914world.com/bbs2/inde...   Nov 23 2020, 05:04 AM
GregAmy   Catch cans are required by most racing orgs to kee...   Nov 23 2020, 07:51 AM
brant   If you put the car onto a track You need an oil p...   Nov 23 2020, 08:02 AM
RolinkHaus   If you were buying a tuna can which one would you ...   Nov 23 2020, 10:39 AM
brant   I haven't really looked very closely at what i...   Nov 23 2020, 11:13 AM
ChrisFoley   I have not looked to see if CFR sells one I h...   Nov 23 2020, 02:32 PM
GregAmy   If you're putting anything 200TW or stickier o...   Nov 23 2020, 11:52 AM
Charles Freeborn   If you're putting anything 200TW or stickier ...   Nov 25 2020, 04:42 AM
brant   [quote name='GregAmy' post='2868767' date='Nov 23...   Nov 25 2020, 09:37 AM
ThePaintedMan   I ran an accusump on a type 4 for around 10 yea...   Nov 25 2020, 11:43 AM
Charles Freeborn   [quote name='GregAmy' post='2868767' date='Nov 2...   Nov 25 2020, 06:05 PM
RolinkHaus   Chris Foley ....Pm'd you   Nov 23 2020, 06:40 PM
RolinkHaus   Looking for this catch can. Pic posted by Kargeek...   Nov 29 2020, 06:02 PM
914werke   I haven't really looked very closely at what ...   Nov 29 2020, 08:08 PM
RolinkHaus   I haven't really looked very closely at what...   Nov 30 2020, 04:43 AM
914werke   Do you have a pic? Of which the Old Welt. versio...   Nov 30 2020, 10:47 AM
RolinkHaus   Yeah, already have one of these. Looking for a oi...   Nov 30 2020, 07:27 PM
GregAmy   I'd love to find a catch can that completely r...   Dec 2 2020, 05:29 PM
Jetsetsurfshop   :driving:   Dec 2 2020, 08:38 PM
Jetsetsurfshop   This is Rev's VW Bug. Jake built the engine fo...   Dec 2 2020, 08:40 PM
GregAmy   So they inserted a bracket/bar across the void and...   Dec 2 2020, 09:32 PM
RolinkHaus   Being that I have a late 1975 does it require a PC...   Dec 3 2020, 05:36 AM
RolinkHaus   In order for the oil catch can (oil breather) to w...   Dec 6 2020, 06:59 AM
GregAmy   The air filter provides no significant vacuum to t...   Dec 6 2020, 08:39 AM
RolinkHaus   Thank you!!   Dec 6 2020, 08:42 AM
GregAmy   Quick correction: I got to re-thinking and just lo...   Dec 6 2020, 10:00 AM
RolinkHaus   Mine has a K&N.   Dec 6 2020, 11:51 AM
brant   A breather box should not be mounted low Also th...   Dec 6 2020, 12:20 PM
Charles Freeborn   Here is mine. Mounts to the cross bar on engine si...   Dec 7 2020, 09:05 PM
stownsen914   Here is mine. Looks like an electric fan setup....   Dec 9 2020, 07:18 AM
Charles Freeborn   Here is mine. Looks like an electric fan setup...   Dec 9 2020, 10:02 AM
ChrisFoley   No need to drill holes thru the sides of the tower...   Dec 8 2020, 09:41 AM
GregAmy   No need to drill holes thru the sides of the towe...   Dec 8 2020, 11:02 AM
ChrisFoley   No need to drill holes thru the sides of the tow...   Dec 8 2020, 12:23 PM
GregAmy   When the aluminum block is rotated into position, ...   Dec 8 2020, 01:03 PM
Jetsetsurfshop   No need to drill holes thru the sides of the towe...   Dec 9 2020, 01:04 PM
Charles Freeborn   Chris' flat fan set up is a thing of beauty. T...   Dec 10 2020, 09:45 PM
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 12:08 PM
