Should I or shouldn't I, to bush or not |
iankarr |
Nov 27 2020, 03:17 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,482 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
I've disassembled the rear of the bumblebee and the control arm pivots and bushings look to be in good shape. My plan was to blast and powdercoat the control arms, which would require removing the pivots/bushings (due to the heat)...but I hear re-installing these can be a beeotch. And I generally prefer keeping as much OEM as possible. So...do you think it's worth leaving the bushings and pivots alone and just painitng the arms? I'm aiming for this bumblebee to be a solid #2 car when done. Thoughts? Thanks! |
Montreal914 |
Nov 28 2020, 12:38 PM
Senior Member Group: Members Posts: 1,597 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
@bdstone914 ; There you go (IMG:style_emoticons/default/smile.gif)
I have a set that will go in your rebuilt trailing arms. Not sure yet how I will proceed. Hoping to see a video from Ian (IMG:style_emoticons/default/popcorn[1].gif) https://914rubber.com/rear-trailing-arm-bus...for-porsche-914 |
Lo-Fi Version | Time is now: 20th June 2024 - 09:15 AM |
