dfelz |
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California ![]() ![]() |
Just split my case, trying to pull the crankshaft from the case half but on the flywheel mounting side it does not want to budge at all from the case! The impeller side is free, but all my efforts of trying to break free the other side did not prevail. Even tried turning the case upside down, with helper holding the crank from the bottom, and me giving some good wacks with the rubber mallet to the top of the piston rod closest to the flywheel from the top, hoping gravity would help, but that still didn’t work... anyone else come across a tight crank that would separate??
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Better I think to tap the flywheel bolts than the piston rod. Mine was stuck this way too and that did the trick. Don't beat it up too much!
dfelz |
Better I think to tap the flywheel bolts than the piston rod. Mine was stuck this way too and that did the trick. Don't beat it up too much! I tried that as well actually. First just hitting the flywheel bolts with the rubber mallet, but not a lot of room with the engine yoke arm below, so then put a 2x2 piece under the bolts and used the yoke arm as leverage and wacked the end of the wood, didn’t budge... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:33 AM |
